Is there an easy way to to build a version of Webmin that will run on this system?
| Milk-V Megrez 32GB/120GB M2 SATA | |
| OS type and version | Debian/RockOS sdcard-rockos-milkv-megrez-2025-0117 |
| Webmin version | REQUIRED |
Webmin runs on any supported OS on any architecture with Perl.
Virtualmin needs a few binary packages. The one that’s probably missing on a new architecture is procmail-wrapper. That means the mail stack won’t work on unsupported architectures if you don’t build that package yourself for your architecture.
Thanks for the reply, I had tried to install as per the instructions but got an error, retried after a sudo su and it all works now, many thanks for the reply.
