| SYSTEM INFORMATION | |
| OS type and version: | RHEL 8.4 |
| Webmin version: | Failed to install |
| Virtualmin version: | Failed to install |
| Related products version: | CentOs 8.4 |
I had CentOs 8.4 minimal installed with nothing installed on a new physical server. I converted it to RHEL 8.4 using some online guide - it actually worked and was simple. It now boots up as RHEL 8.4
I then tried to install virtualmin:
Phase 1 of 3: Setup
Phase 2 of 3: Installation
- Enabling Red Hat CodeReady package repository OK
- Installing EPEL 8 release package OK
- Installing dependencies and system packages [ERROR] Failed with error: 1
[ERROR] Something went wrong. Exiting.
[ERROR] The last few log entries were:- package perl-Log-Log4perl-1.50-1.el8.noarch requires perl(Log::Dispatch::Syslog), but none of the providers can be installed
- conflicting requests
- nothing provides perl(namespace::autoclean) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Devel::GlobalDestruction) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Dist::CheckConflicts) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Params::ValidationCompiler) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio::Declare) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio::Exporter) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio::Library::Builtins) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio::Library::Numeric) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio::Library::String) needed by perl-Log-Dispatch-2.68-1.el8.noarch
- nothing provides perl(Specio) >= 0.32 needed by perl-Log-Dispatch-2.68-1.el8.noarch
Installing dependencies and system packages: [2021-09-20 09:46:04 CEST] [ERROR] Failed with error: 1
[2021-09-20 09:46:04 CEST] [ERROR] Something went wrong. Exiting.
I tried to reinstall, remove etc and nothing works. Virtualmin install/setup wont pass this stage (although Perl is already installed by RHEL). Anybody else seen this after converting from CentOs to RHEL 8?
sh ./install.sh
Will pass the first 2 phases but stops on 3rd when checking dependencies.
