Reverse Proxy (Apache 2.4) and Webmin 2.50
OS type and version | FreeBSD 13.5-u6
Webmin version | 2.520
Reverse Proxy with Apache si working on port 443/tcp well until i9 logon to webmin.
After an successful logon - the URL is redirected to port 8080
I’ve several times checked my config files - but no idea, what’s going wrong :frowning:
Any idea who to fix my strange issue (redirect to port 8080 after my login)
Also example configuration files are welcome :slight_smile:
Regards
Hanes
Ok, there is docs on this, did you follow that?
Hello stefan1959. I spent almost a day searching Google to solve my login feature (redirect to 8080). In your link, I found a tip that I implemented in my CFG… and lo and behold, after logging in, there is no longer a redirect to the original Webmin port :smiling_face_with_sunglasses:
It was the first one for Webmin. I already have other apps running smoothly behind an Apache reverse proxy.
Thank you for removing the scales from my eyes. :ok_hand:
