Restrict enabled features
I would like to have control over some of the enabled features for my virtual domains, but the domain admin is obviously able to arbitrarily enable and disable the displayed features.
Is there any option to prevent certain features from being enabled or disabled?
The reason is, that some features are “paid features” and others should not be disabled in order to harmonize the virtual domains.
Cheers
Vince
You should be able to set that by tweaking the Account Plans. If you go into System Settings -> Account Plans -> Allowed virtual server features, you can enable/disable the features that you want to be available for an account using that particular plan.
Worked for me as long as I leave at least one option enabled … as soon as I disable all options I can’t save it (“Failed to save plan : No default available features selected”)
I can completely disable the whole Edit Virtual Server thing by account plans though … but denying every feature should be possible as there are other options at this section I still want to give access to.
Sounds like a bug, I would suggest filing a bug report under “Issues” so this can be fixed.
