Restore 'fails' with: pg_restore: error: could not execute query: ERROR: schema "public" already exists
This appears to be happening even if the Postgres DB for that account is empty.
Original account was in a server with PG9 (but get the same message on a server with PG13 as well as one with PG15).
Here’s the full output:
virtualmin restore-domain --source /home/for-restore/SITE.com.tar.gz --all-features --domain SITE.com
Checking for missing features ..
.. all features in backup are supported
Checking for errors in backup ..
.. no errors found
Starting restore..
Extracting backup archive file ..
.. done
Re-creating virtual server SITE.com ..
    Creating administration group SITE.com ..
    .. done
    Creating administration user SITE.com ..
    .. done
    Creating aliases for administration user ..
    .. done
    Adding administration user to groups ..
    .. done
    Creating home directory ..
    .. done
    Creating mailbox for administration user ..
    .. done
    Adding new DNS zone ..
    .. done
    Adding to email domains list ..
    .. done
    Adding new virtual website ..
    .. done
    Adding webserver user apache to server's group ..
    .. done
    Performing other Apache configuration ..
    .. done
    Setting up log file rotation ..
    .. done
    Creating PostgreSQL login ..
    .. done
    Creating PostgreSQL database SITE_com ..
    .. done
    Saving server details ..
    .. done
    Re-starting DNS server ..
    .. done
    Applying web server configuration ..
    .. done
Restoring backup for virtual server SITE.com ..
    Restoring virtual server password, quota and other details ..
    .. done
    Updating administration password and quotas ..
    .. done
    Restoring Cron jobs ..
    .. done
    Extracting TAR file of home directory ..
    .. done
    Setting ownership of home directory ..
    .. done
    Re-creating records in DNS domain ..
    .. done
    Restoring Apache virtual host configuration ..
    .. done
    Checking restored PHP execution mode ..
sh: lsof: command not found
    .. mode Apache mod_php cannot be used, switching to FPM.
    Restoring Apache log files ..
    .. done
    Restoring Logrotate configuration ..
    .. done
    Re-loading PostgreSQL database SITE_com ..
    .. load failed! pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 6; 2615 2200 SCHEMA public postgres
Command was: CREATE SCHEMA public;
pg_restore: warning: errors ignored on restore: 1
.. done
Restarting PHP-FPM server ..
.. failed : Job for php-fpm.service failed because the control process exited with error code. See "systemctl status php-fpm.service" and "journalctl -xe" for details.
.. done
Restore failed!
Looking at the last sentence of this response it appears to be because it is being specified. Is Virtualmin doing this on restore? Does the restore script need to be updated? (It appears that the PG database does get restored, but the Restore failed! message might worry some.)
The public schema is a bit of a strange beast, and pg_dump has to
special-case it in some ways. We’ve moved those special cases around
from time to time, too. So one likely explanation here has to do
with version discrepancies between the pg_dump that made the dump
file and the pg_restore that’s restoring it.
Also, I do not think that you’re telling us the whole truth about
how your colleague is running pg_dump and/or pg_restore. There
> shouldn’t be any “CREATE SCHEMA public” issued if you didn’t say
So it looks like the restores were not successful - users (under Virtualmin > domain > Edit Users) were not restored
And then when I go to recreate manually it says:
Failed to save user : Home directory /home/domain.com/homes/contact already exists
What OS and version are you seeing this issue on? Also, since the last comment was over a year ago, do you still have this issue with the latest Virtualmin 7.10.0 and Webmin 2.111?
Sorry for delay in responding. For context in case anyone finds this thread in future, this bit was requested to be added to my post above:
/Edit/
After getting the same again on another server it looks like the error can be ignored, as the domain/account gets restored as usual
Yes, I got the same error importing into a new install (so current version at that time) though the import worked (apart from giving the error). However the backup was from an older version (webmin 1.973 and virtualmin 6.16).
(I no longer have that server so may not be able to carry out any other tests sorry Ilia)
