We are doing a migration.
We are using the Function of Backup/Restore under Virtualmin from a previus backup. Every time we try to restore a domain configurated as a redirection we got the following error :
Extracting backup archive file …
… done
Re-creating virtual server montegonare.com …
… the original parent virtual server does not exist
… failed! See the progress output above for the reason why.
If we use the command line for the restore with the option “–fix” the restore is ok but don’t import the file zone of DNS. No inclusions where insert in Apache configuration.
Any suggestion ?
Thank You
