Restarting fresh?
Hi all,
have searched some forums before this and not found a definitive fix, but I’m looking to delete all of my subdomains/domain and reset virtual min completely fresh as if I have just installed it. I have set up my primary name server wrong and it has been causing me headaches. is there any way to restart from basically scratch? I’m not worried about losing anything currently on the virtualmin domains as I have not done much yet.
OS type and version ubuntu linux 24.04.1
Virtualmin version 7.30.3
Why not just reinstall your OS and literally restart fresh?
But, also, that seems like a drastic move for a DNS server misconfiguration. That’s a tiny thing. Learning a little about DNS so you can fix whatever you did wrong is a worthwhile endeavor.
completely right, my mistake. sorted just using virtualmin tools!
