First I would like to say that Virtualmin has been fantastic for me and I really appreciate there being a GPL version. I’ve installed Virtualmin GPL on a few different servers before and everything went perfect, but this time it is giving me a little bit of trouble.
The webmin login should be: https://vps.grassrootsmarketing.ca:10000/
The virtualmin install log is also attached below.
I’ve had the server providers open ports 10000 and 20000 and they seem to be open. Both httpd and webmin are running and using ‘netstat -tulpn | less’ returns the following:
Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name tcp 0 0 0.0.0.0:20000 0.0.0.0:* LISTEN 3573/perl tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 3283/mysqld tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN 8033/perl tcp 0 0 69.27.107.84:53 0.0.0.0:* LISTEN 3101/named tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 3101/named tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 3364/postmaster tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 3444/master tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 3101/named tcp 0 0 :::993 :::* LISTEN 3380/dovecot tcp 0 0 :::995 :::* LISTEN 3380/dovecot tcp 0 0 :::110 :::* LISTEN 3380/dovecot tcp 0 0 :::143 :::* LISTEN 3380/dovecot tcp 0 0 :::80 :::* LISTEN 4106/httpd tcp 0 0 :::22 :::* LISTEN 3196/sshd tcp 0 0 ::1:953 :::* LISTEN 3101/named tcp 0 0 :::443 :::* LISTEN 4106/httpd udp 0 0 0.0.0.0:10000 0.0.0.0:* 8033/perl udp 0 0 0.0.0.0:20000 0.0.0.0:* 3573/perl udp 0 0 69.27.107.84:53 0.0.0.0:* 3101/named udp 0 0 127.0.0.1:53 0.0.0.0:* 3101/namedShowing that webmin is infact on and listening on port 10000. iptables also has the ports open on my end as they should be.
The other oddity is that using telnet from a different server to port 10000 gives the desired response (saying that it is a bad request and to use https because it is in ssl mode), but when accessing from a browser I just get a ERR_CONNECTION_REFUSED even from http://vps.grassrootsmarketing.ca:10000/ , which should ask me to redirect.
I’m at a lose for what the issue could be. Any help would be greatly appreciated.
Update: I moved mysql from 3306 for now and bound webmin there. I can now access it. Obviously I’m being blocked from port 10000 somehow. I’m trying to get that resolved with my host now. Thanks for the responses.
