Guys, I have a brand new install of Centos 8, I have tried installing SSL on a domain and it keeps failing, now I have the too many tries error. I’d like to know what’s causing this issue. The DNS for the domain seems to be pointing to the IP Address. If you check the DNS to intrelligentconnect.com you’ll see it pointing to the IP Address. DNS Checker - DNS Propagation Check & DNS Lookup (whatsmydns.net) I also have Certbot installed as well. Here’s the error found in var/log/letsencrypt… Any suggestions on how to fix this issue?. Thanks in advance.
2021-07-23 13:17:55,258:DEBUG:certbot._internal.log:Exiting abnormally: Traceback (most recent call last): File "/bin/letsencrypt", line 11, in <module> load_entry_point('certbot==1.14.0', 'console_scripts', 'certbot')() File "/usr/lib/python3.6/site-packages/certbot/main.py", line 15, in main return internal_main.main(cli_args) File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 1435, in main return config.func(config, plugins) File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 1304, in certonly lineage = _get_and_save_cert(le_client, config, domains, certname, lineage) File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 140, in _get_and_save_cert lineage = le_client.obtain_and_enroll_certificate(domains, certname) File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 444, in obtain_and_enroll_certificate cert, chain, key, _ = self.obtain_certificate(domains) File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 374, in obtain_certificate orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names) File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 406, in _get_order_and_authorizations orderr = self.acme.new_order(csr_pem) File "/usr/lib/python3.6/site-packages/acme/client.py", line 880, in new_order return cast(ClientV2, self.client).new_order(csr_pem) File "/usr/lib/python3.6/site-packages/acme/client.py", line 658, in new_order response = self._post(self.directory['newOrder'], order) File "/usr/lib/python3.6/site-packages/acme/client.py", line 86, in _post return self.net.post(*args, **kwargs) File "/usr/lib/python3.6/site-packages/acme/client.py", line 1198, in post return self._post_once(*args, **kwargs) File "/usr/lib/python3.6/site-packages/acme/client.py", line 1211, in _post_once response = self._check_response(response, content_type=content_type) File "/usr/lib/python3.6/site-packages/acme/client.py", line 1068, in _check_response raise messages.Error.from_json(jobj) acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/ 2021-07-23 13:17:55,263:ERROR:certbot._internal.log:An unexpected error occurred: 2021-07-23 13:17:55,263:ERROR:certbot._internal.log:There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
Plugins selected: Authenticator webroot, Installer None
Requesting a certificate for intrelligentconnect.com
Performing the following challenges:
http-01 challenge for intrelligentconnect.com
Using the webroot path /home/intrelligentconnect/public_html for all unmatched domains.
Waiting for verification...
Challenge failed for domain intrelligentconnect.com
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: intrelligentconnect.com
Type: unauthorized
Detail: Invalid response from
http://intrelligentconnect.com/.well-known/acme-challenge/sa3_f6BOYyEDZHJ1qO4Z_j1V1Qrh6P8AAlbZ-uvaiOE
[2604:a880:400:d0::20bb:1]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD
HTML 2.0//EN\">\n<html><head>\n<title>404 Not
Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
Plugins selected: Authenticator manual, Installer None
Please see the logfiles in /var/log/letsencrypt for more details.
Centos 8.4
Webmin 19.73
VM 6.16
SYSTEM INFORMATION | |
OS type and version: | REQUIRED |
Webmin version: | REQUIRED |
Virtualmin version: | REQUIRED |
Related products version: | RECOMMENDED |
