I’m trying to remove the webmin-virtualmin-mailman module, as I’d like to manage Mailman myself on the server as I’m planning on using the com_mailman2 Joomla Bridge http://www.backupcentral.com/content/view/108/47/
When I attempt to remove the webmin-virtualmin-mailman module from within Virtualmin I get the following error:
Failed to delete package webmin-virtualmin-mailman :
dpkg: dependency problems prevent removal of webmin-virtualmin-mailman:
virtualmin-base depends on webmin-virtualmin-mailman; however:
Package webmin-virtualmin-mailman is to be removed.
Package webmin-virtualmin-mailman which provides webmin-virtualmin-mailman is to be removed.
dpkg: error processing webmin-virtualmin-mailman (–remove):
dependency problems - not removing
Obviously I don’t want to unstall virtualmin-base as that will cause a few issues
Following on from this, due to the same dependency issue, I can’t remove mailman either with apt trying to uninstall virtualmin-base as well
root@us:/home/admin# apt-get remove mailman
Reading package lists… Done
Building dependency tree… Done
The following packages will be REMOVED:
mailman virtualmin-base
Thanks,
Matt<br><br>Post edited by: bofh, at: 2007/12/19 13:17
