I removed BIND from my server a while ago as all of my domains use the registrars name servers.
Previously if I wanted to remove an autogenerated sub domain such as admin.domain.com or webmail.domain.com I could do this from the Virtual hosts DNS configuration option, however, that is no longer present since I removed BIND.
Is there a way to manually remove those entries? They are currently preventing Lets Encrypt certificate generation as I don’t have those entries setup at the registrar - and I’d rather not manually add them for all of my domains.
In Virtualmin → System Settings → Server Templates: Click Default Settings and then Edit template section: Website for domain; and disable redirects that you do not want.
Caveat: I have never tested this actually, but I expect it to work. Let us know how it goes, please.
I tried re-enabling bind temporarily, and that adding it the virtual host config this did remove those extra domains but as soon as I disabled bind, the extra subdomains were added again.
