I made the mistake of choosing find Physical Systems and it looked on my network. Issue now is it is listing every IP that responded to a ping on my network. I have about 100 nodes that now show up in the list managed systems and only 10 of those are virtualmin systems.
How do I remove the rest. I have looked on the forum and in the documentation and I cant find it. cloudmin delete-system command does not work because they show as Physical systems in list-systems
I believe you can solve that by going into List Managed Systems, selecting the checkbox next to the ones you wish to remove – and then going all the way to the bottom of the page where you can select “De-Register”.
That should tell Cloudmin to stop displaying those particular systems.
