I got it to work with those commands:
sudo firewall-cmd --zone=public --add-port=3389/tcp --permanent
sudo firewall-cmd --reload
Problem:
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu 22.04.04 |
| Virtualmin version | Virtualmin 7.3.4 |
When I install Virtualmin on Webmin version (2.105), my xrdp version(0.9.17-2ubuntu2) (for Remote desktop connection) won’t work correctly anymore. It does not connect to the server anymore with Windows 11 “Remote Desktop Connection” software.
I also get such errors from xrdp after installing Virtualmin:
[ERROR] xrdp_sec_recv: xrdp_mcs_recv failed
[ERROR] xrdp_rdp_recv: xrdp_sec_recv failed
[ERROR] libxrdp_process_data: xrdp_rdp_recv failed
[ERROR] xrdp_process_data_in: xrdp_process_loop failed
[ERROR] xrdp_iso_send: trans_write_copy_s failed
[ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
I installed on Ubuntu with preinstalled Webmin from Contabo… The commands I write after preinstalled Webmin server to get the bug:
sudo apt update
sudo apt install xfce4 xfce4-goodies -y
sudo apt install xrdp -y
wget https://software.virtualmin.com/gpl/scripts/virtualmin-install.sh
sudo sh virtualmin-install.sh --bundle LEMP
What Remote Desktop software are you using with Ubuntu which would work with Virtualmin 7.3.4?
