Remarks on using 7.50.2 GPL in production
OS type and version AlmaLinux 10.1
Webmin version 2.6.10
Virtualmin version 7.50.2 GPL
Webserver version Nginx 1.26.3
Related packages Nginx, Dovecot, Postfix
I encountered some issues using Virtualmin in production. Hopefully you can use my suggestions to improve the software.
  1. when installing with “virtualmin-install.sh -b LEMP” I had to add these packages manually: wbm-virtualmin-nginx wbm-virtualmin-nginx-ssl wbm-jailkit wbm-php-pear
  2. in some cases the LetsE SSL certificate contained the domain name mail.$(DOM) while there was no “Mail for domain” feature selected. This has caused me some headaches…
    I have not found exactly when this happened, but I think it was at creating a new server using a custom template. I could not find anything in the SSL settings of the template.
  3. The default security can be improved a lot by:
  • Server Templates - SSL website for domain - Default SSL key size = 2048
  • Server Templates - SSL website for domain - Default SSL certificate hash = ECC
  • Webmin - SSL support - Enforce SSL = Yes, with HSTS header
  • Webmin - SSL support - SSL protocol versions to reject = SSLv2 SSLv3 TLSv1.0 TLSv1.1
  • Webmin - SSL support - Allowed SSL ciphers = Only strong ciphers with PFS
  • Dovecot IMAP/POP3 - SSL Configuration - Disallow plaintext non-SSL mode = Yes
  • Postfix Mail Server - SMTP Authentication - Disallow SASL over insecure conns = Yes
  • /etc/postfix/main.cf:
    smtpd_tls_mandatory_ciphers = high
    smtpd_tls_mandatory_protocols = >=TLSv1.2
    smtp_tls_mandatory_ciphers = high
    smtp_tls_mandatory_protocols = >=TLSv1.2
    smtpd_tls_dh1024_param_file = /etc/pki/ffdhe4096.pem
  • /etc/nginx/nginx.conf - http {}:
    server_tokens off;
    http2 on;
    ssl_protocols TLSv1.3 TLSv1.2;
    ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-CHACHA20-POLY1305;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 1h;
    fastcgi_hide_header X-Powered-By;
    add_header Strict-Transport-Security “max-age=31536000; includeSubDomains” always;
The above gives you an A+ rating at the Qualsys SSL test.
  1. fastcgi_param SCRIPT_FILENAME and DOCUMENT_ROOT contain a copy of the path to public_html, just as the Nginx root directive. These parameters are not updated when the server root is altered within Virtualmin.
    Consider to use $document_root in SCRIPT_FILENAME and DOCUMENT_ROOT to avoid duplication of the entire root in the Nginx configuration, and also avoid issues with escaping and quoting paths.
  2. virtual servers have no try_files and Nginx has no default. I had to add try_files myself to most servers to get PHP software working.
    Consider to always set a decent try_files in the server block: try_files $uri $uri/ /index.php$is_args$args;
So far I only installed simple PHP software and several WordPress sites. More suggestions will likely follow when I start using Nextcloud, Laravel apps and mail services.
https://www.virtualmin.com/docs/os-support/
Alma Linux 10.x is supported for next Virtualmin release 8
Search the forum and you will find much information about this
Thanks for your suggestions.
That’s very odd, it shouldn’t happen. Those packages should install automatically. How did you install Virtualmin exactly?
@Jamie, Can you comment on this, please?
Only my first item may be AlmaLinux 10 specific.
The others are generic to Virtualmin with Nginx.
I have tested Virtualmin on AlmaLinux 10 for a few months, with both Apache-LAMP and Nginx-LEMP stacks.
Now I start using it for real with 10 domains where 3 have a mailserver. So far no big issues, just some details that I also encounter on supported Linux versions.
I have also done several security checks that delivered the suggestions in item 3.
This weekend I hope to do some specific PEN-tests on all edge services.
@fd1
sounds good :+1:
wget https://software.virtualmin.com/gpl/scripts/virtualmin-install.sh
chmod 750 virtualmin-install.sh
./virtualmin-install.sh -b LEMP
Looking back at my notes, there was also a message about AWStats being missing.
That is correct for Alma/Rocky/RHEL 10, because AWStats is not actively maintained anymore.
Maybe a missing AWStats package caused the installation to skip the ones I mentioned.
This version of the installer does not support Alma 10, and you should expect a number of problems trying to use it there. Our supported operating systems are listed on the OS support page, and when you run the installer.
There is a pre-release version of the script (and repos) that supports Alma 10 that has been linked several times by Ilia here in the forums.
This is intentional, as even if the email feature is disabled it is still possible to send email through the system. That said, the mail sub-domain should only be added to the SSL cert if it can be externally resolved.
