i’m having a nickel of a dime time trying to quarter php-soap into my webmin/virtualmin server.
i’ve tried bribing the server with yum install php-soap. it took the moola and installed soap 5.4 i think.
but that can’t buy me any tortillas because i’m using php7.0. so the version i need is the version that will work with php7.0.
when i check phpinfo for my installation (which has php7.0), no soap is found.
but when i switch the php version to 5.4 and check phpinfo, then i see soap enabled.
i have tried to womanually add extension=’/usr/lib/php/modules/soap.so’ to the php.ini file and restarted almighty apache. but it still didn’t accept my prayers.
is there a simpler way of choosing from available php extensions from webmin/virtual interface?
i’m beginning to stink. i need this soap badly. pls help.
hey eric,
thanks for the quick reply.
yes i’ve already tried: yum install php70-soap , and yum install php7.0-soap
neither worked.
but now it seems i must have messed something up on the server, because when i run yum search soap | grep php
it returns a scary output:
[root@panel ~]# yum search soap | grep php
error: rpmdb: BDB0113 Thread/process 9901/139878449698624 failed: BDB1507 Thread died in Berkeley DB library
error: db5 error(-30973) from dbenv->failchk: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
error: cannot open Packages index using db5 - (-30973)
error: cannot open Packages database in /var/lib/rpm
CRITICAL:yum.main:
eric to the rescue! yes, that solution fixed my rpmdb issue. thanks a lot for that.
now here’s output of yum search soap | grep php :
php-ZendFramework-Soap.noarch : SOAP web services server part helper
php-ZendFramework2-Soap.noarch : Zend Framework 2: SOAP Component
php-pear-SOAP.noarch : Simple Object Access Protocol (SOAP) Client/Server for
php-soap.x86_64 : A module for PHP applications that use the SOAP protocol
php54-php-soap.x86_64 : A module for PHP applications that use the SOAP protocol
php55-php-soap.x86_64 : A module for PHP applications that use the SOAP protocol
rh-php56-php-soap.x86_64 : A module for PHP applications that use the SOAP
rh-php70-php-soap.x86_64 : A module for PHP applications that use the SOAP
rh-php71-php-soap.x86_64 : A module for PHP applications that use the SOAP
