In my virtual server, the postfix server is configured for receiving not only e-mails from my “main” website (@domain1.com users), but also for another domain configured as sub-server (@domain2.com users).
The configuration for receiving mails from @domain2.com users (the domain configured as sub-server in Virtualmin) was achieved through defining the variable virtual_alias_domains = domain2.com within the configuration file /etc/postfix/main.cf, and then defining the accounts mapping inside /etc/postfix/virtual.
This configuration is working, i.e. I can receive e-mails for both domains without issue. But when I run the “Re-check configuration” script in Virtualmin > System Settings I get the following error message:
Your Postfix configuration has the virtual_alias_domains option set to domain2.com. This overrides the list of domains from the virtual_alias_maps option, and should be removed
If I remove the definition of virtual_alias_domains inside main.cf, the e-mails for domain2.com will not be received anymore. How should I then configure postfix to receive e-mails for my sub-server domain, so that I do not get any errors from “Re-check configuration” script?
I’ve added as the first line (on top of my virtual mappings within the file /etc/postfix/virtual) the virtual alias domain definition, just like your recommendation.
But as soon as I comment out the virtual_alias_domains definition within /etc/postfix/main.cf, my e-mails do not get delivered to the addresses defined by /etc/postfix/virtual. So it seems that my domain definition at the top of /etc/postfix/virtual isn’t being “recognized” by postfix.
I tried also to change this domain definition to the bottom of the file, but that didn’t work as well.
Maybe I’m forgetting something? Or what could I execute wrong while adding the domain definition? I just wrote a line like this:
mysubserverdomain.com my_comment
Where the domain name and the comment are separated by a tab.
You definitely should not use virtual_alias_domains.
I guess something is wrong with the virtual maps file. Did you run postmap on it, after editing it? (If you edit in Virtualmin, this is done automatically.)
