steven
April 15, 2008, 2:33am
1
Hello
I have virtualmin pro on a vps and whenever I reboot the server, the user/groups quotas have to be re-enabled on /
(through ‘Disk and Network Filesystems’ > ‘/ (Root filesystem) -Linux Native Filesystem (ext3)’ > 'Use Quotas? - User and Group > Save)
Something is being overwritten when the VPS is started but I am not sure. Can someone please help…
Do you have a “disk quotas” module in the system category? If so be sure it’s enabled there also before you reboot. YOu didn’t say your OS or VMPro version. THat’s always helpful
Joe
April 16, 2008, 12:23am
3
Some VPS systems copy files around on boot. Make sure whatever the source for the mtab and fstab is has the right data.
steven
April 16, 2008, 6:49am
4
Sorry, It is a VPS ‘slice’ from slicehost.com
Centos 5.1 on Xen virtualization
Yeah, disk quotas is enabled. I have to set this after I do the ‘Disk and Network Filesystems’ thing. After reboot it is lost again.
Joe, I have no idea what you just said
steven
April 16, 2008, 7:12am
6
I refer to this post here http://www.virtualmin.com/forums/hacks/quotas-and-reiserfs.html
I have tried both /etc/mtab and /etc/fstab and problem still exists.
Here is the contents of my /etc/fstab
[code:1]
This file is edited by fstab-sync - see ‘man fstab-sync’ for details
/dev/sda1 / ext3 errors=remount-ro,noatime 0 1
/dev/sda2 none swap sw 0 0
proc /proc proc defaults 0 0
none /dev/pts devpts gid=5,mode=620 0 0
none /dev/shm tmpfs defaults 0 0
/dev/simfs / reiserfs usrquota,grpquota 0 0
[/code:1]
here is my mtab
[code:1]
/dev/sda1 / ext3 rw,noatime,errors=remount-ro 0 0
proc /proc proc rw 0 0
none /dev/pts devpts rw,gid=5,mode=620 0 0
none /dev/shm tmpfs rw 0 0
none /proc/sys/fs/binfmt_misc binfmt_misc rw 0 0
[/code:1]
Are you sure you’re on CentOS 5.x? I note the distinction in the beginning comment line. The following are fstabs from 4.6 and 5.1 respectively:
fstab 4.6
/dev/VolGroup00/LogVol00 / ext3 grpquota,suid,dev,usrquota,exec 0 1
LABEL=/boot /boot ext3 defaults 1 2
none /proc proc defaults 0 0
none /sys sysfs defaults 0 0
/dev/VolGroup00/LogVol01 swap swap defaults 0 0
/dev/hdd /media/cdrom auto pamconsole,exec,noauto,managed 0 0
fstab 5.1
/dev/VolGroup00/LogVol00 / ext3 grpquota,usrquota,rw 0 1
tmpfs /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts gid=5,mode=620 0 0
sysfs /sys sysfs defaults 0 0
I think what Joe was referencing is that your fstab has no boot assigned, something you don’t have access to may be over riding your settings in a read only file.
This would be mtab:
/dev/mapper/VolGroup00-LogVol00 / ext3 rw,grpquota,usrquota 0 0
sysfs /sys sysfs rw 0 0
devpts /dev/pts devpts rw,gid=5,mode=620 0 0
/dev/hda1 /boot ext3 rw 0 0
tmpfs /dev/shm tmpfs rw 0 0
sunrpc /var/lib/nfs/rpc_pipefs rpc_pipefs rw 0 0
This should give you something working on a standard box to compare.
