| SYSTEM INFORMATION | |
| OS type and version | REQUIRED |
| Webmin version | REQUIRED |
Please could someone help with this:
I have an existing DNS server, Bind enabled, etc. I setup PTR records for a subnet of IPs(for ex: a.b.c.d/24) on it sometime back, and everything is currently working fine. It has just 1-master zone(domainA.com). DomainA is properly setup from the registrar.
Dig command locally gives correct results
If I do a PTR lookup from mxtoolbox.com, or any lookup portal, I see the correct results.
This week, I added another master zone(domainB.com - same registrar setup as above) and setup PTR records for a different IP-subnet(for ex: w.x.y.z/24) just the same way I set up the first one above.
Command dig -x ip-address @ns-server-ip shows the correct information locally on the server: I mean I can see the below info correctly.
;; ANSWER SECTION:
x.x.x.x.in-addr.arpa. 3600 IN PTR x.x.x.x.ptr-name/label
However if I try to do a remote PTR lookup from mxtoolbox or any lookup site online, it gives the error PTR record not found.
Is it not possible to have 2-master zones on same server? or is there something else I should do / define somewhere?
Note: PTR lookups for the first IP-subnet are working, while PTR records for the new IP-subnet arent, on same server, reachable from the internet
thanks for the help
TK
