fredv
February 26, 2025, 11:32am
1
I’m using Proxy Path with different URL Path but I also need to have the root URL Path /
The problem is that when Root / is set, i cannot add other URL Path because the / will be applied first.
Is there a way to sort the order in which the Proxy Paths will be used ? to be able to set the Root at the end ?
Ilia
February 27, 2025, 7:34pm
2
We currently don’t have an option to sort added proxy paths. However, you could manually edit the web server configuration or delete the rule you want to prioritize and re-add it.
fredv
February 28, 2025, 8:59am
3
Yes that’s exactly what i’m doing right now but of course, a way to sort with GUI would be fine later
Thanks for your answer
Add a well formed feature request on GitHub and then it can go on the list to be looked at.
system
Closed
March 8, 2025, 9:03am
5
