Hello
I have a fresh instalation, of Ubuntu 10.04.1 on a virtual machine
installed Virtualmin, with no other issues, except the proftpd was stopped, and not starting
when i tried to start it via virtualmin
I get this :
Failed to start FTP server :
Starting ftp server proftpd
Illegal instruction
…fail!
no changes were made in config file it is defaut configuration, and log is empty.
PS I am new, to linux normaly i would reinstall whole server, but i have migrated some websites there, via ssh. ftp is needed for some website services
It is a www.intovps.com provided service
forgot to mention that ubuntu is 64bit
i do not think it has anything to do with provider, otherwise it would affect other services
Yeah, I’ve never experienced errors such as that on a default install either, except on OpenVZ installs
That user_beancountesr file a list of memory parameters on OpenVZ-based systems.
It looks like the “numproc” has a “failcnt” of 7 – that means that your provider is limiting the number of processes you can run at once, and on 7 different occasions, a process attempted to start, and was rejected due to the constaints.
Out of curiosity, if you run “proftpd -n” again, does that “failcnt” column for “numproc” go up to 8?
Well, that’s good, though it’s unclear why you’re getting that error.
Something strange is going on
You said you checked the logs – I just wanted to verify that /var/log/proftpd/proftpd.log was one of the logfiles you had looked at.
Also, what output do you get if you run this command:
dmesg | tail -15
That should show if there’s any recent kernel errors.
Also, could you attach your /etc/proftpd/proftpd.conf file? I can try using your config on one of my test systems, and see if I’m able to provoke that error.
/var/log/proftpd is an empty directory
dmesg | tail -15 has no output at the moment
atached my proftpd.conf file, it is the default config that came with virtualmin - have some fun (just change extension)
Well, Virtualmin doesn’t provide the ProFTPd package, that’s pulled down from apt… so there’s room for something to go awry if something were unusual about the repository, or during the package installation.
Now, all that is all really unlikely, but you’re also the first person to post here about this particular problem, so we’re already within the “unlikely” realm of things
I’ll test that config and see if any issues stand out.
Okay, as you predicted, I’m not seeing anything unusual with your config file. When I place it on my test Ubuntu system, ProFTPd starts up just fine.
I’m running out of ideas as to what to suggest… there’s nothing unusual about ProFTPd on a Virtualmin system, it’s simply pulled down from the Ubuntu apt repository during Virtualmin installation. No additional configuration is done to that.
So, we should be dealing with an Ubuntu default.
When a default such as that doesn’t work, it starts to point to the unusual… corrupt packages, disk errors, memory problems… and other yucky things
Perhaps we ought to verify the package that you have… can you run this command:
dpkg -l ‘proftpd*’
That should show what version of ProFTPd you have, as well as where it came from.
Also, the tool “debsums” can help in determining if something somehow became corrupt. You can install that by running this command:
after the instalation scp -rp remoteuser@server.com/dir /localdir got backups from remote server
extracted backups (virtual minbackups)
stoped dovecot, clam, postgres, spam
so no configuration or anything else to mess up, didnt had a chance yet…
dpkg -l ‘proftpd*’ gives us this outpot
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Description
un proftpd (no description available)
un proftpd-abi-1. (no description available)
ii proftpd-basic 1.3.2c-1ubuntu Versatile, virtual-hosting FTP daemon - bina
un proftpd-doc (no description available)
un proftpd-mod-ld (no description available)
un proftpd-mod-my (no description available)
un proftpd-mod-od (no description available)
un proftpd-mod-pg (no description available)
un proftpd-mod-sq (no description available)
and output of debsums
root@vh11:~# apt-get install debsums
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
debsums
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 48.2kB of archives.
After this operation, 274kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ lucid/universe debsums 2.0.48 [48.2kB]
Fetched 48.2kB in 0s (506kB/s)
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 75, <> line 1.)
debconf: falling back to frontend: Readline
Preconfiguring packages …
Selecting previously deselected package debsums.
(Reading database … 65176 files and directories currently installed.)
Unpacking debsums (from …/debsums_2.0.48_all.deb) …
Setting up debsums (2.0.48) …
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 75.)
Hmm what can go wrong, if the only comands and configs during instalation was … no configuration or anything else to mess up, didnt had a chance yet…
I completely understand, and I don’t think you did anything wrong
I don’t see anything suspicious in your debsums output.
So, I’m fresh out of ideas as to what we can look at on your system.
I think the next step is to talk to your provider, tell them you receive an “Illegal instruction” error anytime you attempt to start your default ProFTPd install, and ask them if they’re seeing any memory disk, or other errors related to your installation.
I suppose another alternative is that some security system could be running on your setup that’s causing problems… things like SELinux, grsecurity, and the like are capable of causing that.
It shouldn’t be a problem on a default Ubuntu installation – but it’s difficult to know what all a provider setup with their distribution images. You may want to ask if they’re aware of any security settings that could cause that.
Since you’re using Ubuntu 10.04 x64, just like me: Do you also get an error for proftpd -v? If not, what version is installed? You can check that in aptitude too.
Okay, I have the same version and am getting a different checksum. So it’s possible the binary (or maybe further files too) are corrupted… Maybe try reinstalling only the ProFTPD package first?
What’s your output for uname -a ?
Mine is: Linux lyra 2.6.32-33-server #71-Ubuntu SMP Wed Jul 20 17:42:25 UTC 2011 x86_64 GNU/Linux
Ok, as i got advice from vps support to reinstall, and they also could not find anything wrong.
I did the rinstall multiple times last night, just to check
And run in to more intresting issues…
did the clean install of Ubuntu 10.04 x64, apt update then upgrade, clean virtualmin install via script, same problem apeared.
did the second reinstall with just same OS , just apt update and no upgrade, clean virtualmin install via script - same problem
took Ubuntu 10.04 x32 same scenario
Debian 6 x64 - install script ran for an frustrating 1 hour, i just reinstalled server to x32
Debian 6 x32 - Everything went fine, everyting works
by the way, before taking ubuntu, I tried Debian 5 which works perfect, but it did not fit with the subversion version, It has subversion 1.5.5 or something like that i had to have 1.6.6 or higher.
So thanks all of you, your help is apriciated, hope this discussion will solve some this problem to other people.
