Virtualmin on Almalinux 9. This is the config file:
# Load DSO modules as required
Include /etc/proftpd/conf.d
# Server Config - config used for anything outside a <VirtualHost> or <Global> context
# See: http://www.proftpd.org/docs/howto/Vhost.html
# Trace logging, disabled by default for performance reasons
# (http://www.proftpd.org/docs/howto/Tracing.html)
#TraceLog /var/log/proftpd/trace.log
#Trace DEFAULT:0
ServerName "ProFTPD server"
ServerIdent on "Oh Hi!"
ServerAdmin xxx@xxxxcom
DefaultServer on
# Cause every FTP user except adm to be chrooted into their home directory
DefaultRoot ~ !adm
# Use pam to authenticate (default) and be authoritative
AuthPAMConfig proftpd
AuthOrder mod_auth_pam.c* mod_auth_unix.c
# If you use NIS/YP/LDAP you may need to disable PersistentPasswd
#PersistentPasswd off
# Don't do reverse DNS lookups (hangs on DNS problems)
UseReverseDNS off
# Set the user and group that the server runs as
User nobody
Group nobody
# To prevent DoS attacks, set the maximum number of child processes
# to 20. If you need to allow more than 20 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode; in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 20
# Disable sendfile by default since it breaks displaying the download speeds in
# ftptop and ftpwho
UseSendfile off
# Define the log formats
LogFormat default "%h %l %u %t \"%r\" %s %b"
LogFormat auth "%v [%P] %h %t \"%r\" %s"
# Don't log hostname or timestamps because systemd will do that for us
LogOptions -Timestamp -Hostname +RoleBasedProcessLabels
# Enable basic controls via ftpdctl
# (http://www.proftpd.org/docs/modules/mod_ctrls.html)
ControlsEngine on
ControlsACLs all allow user root
ControlsSocketACL allow user *
ControlsLog /var/log/proftpd/controls.log
# Enable admin controls via ftpdctl
# (http://www.proftpd.org/docs/contrib/mod_ctrls_admin.html)
<IfModule mod_ctrls_admin.c>
AdminControlsEngine on
AdminControlsACLs all allow user root
</IfModule>
# Enable mod_vroot by default for better compatibility with PAM
# (http://bugzilla.redhat.com/506735)
<IfModule mod_vroot.c>
VRootEngine on
</IfModule>
# TLS (http://www.castaglia.org/proftpd/modules/mod_tls.html)
# Enable this with PROFTPD_OPTIONS=-DTLS in /etc/sysconfig/proftpd
<IfDefine TLS>
Include /etc/proftpd/mod_tls.conf
</IfDefine>
# Dynamic ban lists (http://www.proftpd.org/docs/contrib/mod_ban.html)
# Enable this with PROFTPD_OPTIONS=-DDYNAMIC_BAN_LISTS in /etc/sysconfig/proftpd
<IfModule mod_ban.c>
Include /etc/proftpd/mod_ban.conf
</IfModule>
# Set networking-specific "Quality of Service" (QoS) bits on the packets used
# by the server (http://www.proftpd.org/docs/contrib/mod_qos.html)
<IfModule mod_qos.c>
Include /etc/proftpd/mod_qos.conf
</IfModule>
# Global Config - config common to Server Config and all virtual hosts
<Global>
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable
Umask 022
# Allow users to overwrite files and change permissions
AllowOverwrite yes
DefaultRoot ~
</Global>
TLSCACertificateFile /etc/proftpd.ca
SystemLog /var/log/proftpd/proftpd.log
# A basic anonymous configuration, with an upload directory
# Enable this with PROFTPD_OPTIONS=-DANONYMOUS_FTP in /etc/sysconfig/proftpd
<IfDefine ANONYMOUS_FTP>
Include /etc/proftpd/anonftp.conf
</IfDefine>
# Include other custom configuration files
And this is the other virtualmin conf for it:
<Global>
PassivePorts 49152 65535
AllowOverwrite on
RootLogin off
</Global>
# chroot users into their home by default
DefaultRoot ~
# Enable TLS
LoadModule mod_tls.c
TLSEngine on
TLSRequired on
TLSRSACertificateFile /etc/pki/tls/certs/proftpd.pem
TLSRSACertificateKeyFile /etc/pki/tls/private/proftpd.pem
TLSOptions NoSessionReuseRequired
TLSVerifyClient off
TLSLog /var/log/proftpd/tls.log
<IfModule mod_tls_shmcache.c>
TLSSessionCache shm:/file=/var/run/proftpd/sesscache
</IfModule>
# VirtualHost for SFTP (FTP over SSH) port
LoadModule mod_sftp.c
<VirtualHost 0.0.0.0>
SFTPEngine on
SFTPLog /var/log/proftpd/sftp.log
# Configure the server to listen on 2222 (openssh owns 22)
Port 2222
# Configure the RSA and ECDSA host keys, using the same host key
# files that OpenSSH uses.
SFTPHostKey /etc/proftpd/ssh_host_rsa_key
SFTPHostKey /etc/proftpd/ssh_host_ecdsa_key
# Configure the file used for comparing authorized public keys of users.
SFTPAuthorizedUserKeys file:~/.sftp/authorized_keys
# Enable compression
SFTPCompression delayed
# More then FTP max logins, as there are more ways to authenticate
# using SSH2.
MaxLoginAttempts 6
DefaultRoot ~
</VirtualHost>
If you installed Virtualmin via the install script the log file should be configured for you. You should not be setting a log files for it. Have you done a ftp login?
I had the same on Ubuntu, it turned out fail2ban had it’s backend configured to systemd, I changed this to auto & everything worked
note :-
I changed this in jail.conf to make it global rather than jail.local
if you do this don’t forget to restart fail2ban
I’m trying to get a new server running on Almalinux 9. So far, everything looks good I think
I can confirm the problem.
I’m not sure, but maybe something is misconfigured here. Below is my proftpd.conf from Fail2ban
[INCLUDES]
before = common.conf
[Definition]
_daemon = proftpd
__suffix_failed_login = ([uU]ser not authorized for login|[nN]o such user found|[iI]ncorrect password|[pP]assword expired|[aA]ccount disabled|[iI]nvalid shell: '\S+'|[uU]ser in \S+|[lL]imit (access|configuration) denies login|[nN]ot a UserAlias|[mM]aximum login length exceeded)
prefregex = ^%(__prefix_line)s%(__hostname)s \(\S+\[<HOST>\]\)[: -]+ <F-CONTENT>(?:USER|SECURITY|Maximum) .+</F-CONTENT>$
failregex = ^USER <F-USER>\S+|.*?</F-USER>(?: \(Login failed\))?: %(__suffix_failed_login)s
^SECURITY VIOLATION: <F-USER>\S+|.*?</F-USER> login attempted
^Maximum login attempts \(\d+\) exceeded
ignoreregex =
[Init]
journalmatch = _SYSTEMD_UNIT=proftpd.service
Additionally, in my /var/log/messages file, I found this entry when I tried to log in with wrong credentials:
Apr 6 12:21:20 test proftpd[1931]: session[1931] 207.123.456.175 (189.123.456.195[189.123.456.195]): USER deanm: no such user found from 189.123.456.195 [189.203.106.195] to ::ffff:207.123.456.175:21
I changed also all the fail2ban’s to pyinotify, as well those which are in /var/fail2ban/paths-fedora.conf
I’m not sure what’s exactly wrong here, maybe someone can help out?
