So I updated a few packages using Virtualmin today, and procmail (while still running) has stopped processing my ~/.procmailrc
file. It is, however, still processing the /etc/procmailrc
file. And I have no idea why.
I can tail /var/log/procmail.log
and watch new items being filtered (until it ‘assumes identity of the recipient’) but tailing ~/.procmail/log
shows nothing new being added (which means my ~/.procmailrc
isn’t being processed, I think?)
I’m still learning all the virtualmin ropes, but after hours bashing my head against this I’m just hoping someone can point me in the right direction
I’m using:
Ubuntu 10.04.1 LTS i686
Virtualmin 3.82-2.gpl (3.81 previous to this problem)
Postfix 2.7.0-1
Procmail 3.22-18ubu
Procmail-Wrapper 1.0-2
According to the virtualmin logs, security-updates/update.cgi
updated the following packages:
mysql-client mysql-common libmysqlclient16 mysql-client-core-5.1 mysql-client-5.1 mysql-server mysql-server-core-5.1 mysql-server-5.1 postgresql-client-common postgresql-common webmin-virtual-server webmin-virtual-server-theme
I’m fairly sure it’s related to one of these updated packages. Emails a minute prior to the time of update were filtered into folders; emails a minute the update are all just dropping into my Inbox.
None of those packages appeared to relate to procmail at first glance.
Postfix is set up to call procmail-wrapper
like this, so no .forward
file exists but none has been needed previously:
The ~/.procmailrc
file hasn’t changed in weeks. Just to make things easier to test, I’ve simplified it to look like the below.
MAILDIR=$HOME/Maildir
PMDIR=$HOME/.procmail
SHELL=/bin/sh
LOGFILE=$PMDIR/log
VERBOSE=yes
:0
.Testingness/
And it has permissions/ownership set up like so:
-rw-r–r-- 1 myusername myusername 108 Nov 17 09:04 .procmailrc
The /etc/procmailrc
file looks like this (should be stock):
VERBOSE=on
LOGFILE=/var/log/procmail.log
TRAP=/etc/webmin/virtual-server/procmail-logger.pl
:0wi
VIRTUALMIN=|/etc/webmin/virtual-server/lookup-domain.pl $LOGNAME
:0
- ?/usr/bin/test “$VIRTUALMIN” != “”
INCLUDERC=/etc/webmin/virtual-server/procmail/$VIRTUALMIN
DEFAULT=$HOME/Maildir/
ORGMAIL=$HOME/Maildir/
DROPPRIVS=yes
:0
$DEFAULT
When mail arrives, something like this gets added to /var/log/procmail.log:
procmail: Assigning “TRAP=/etc/webmin/virtual-server/procmail-logger.pl”
procmail: Assigning “VIRTUALMIN=”
procmail: Executing “/etc/webmin/virtual-server/lookup-domain.pl,myusername”
procmail: [12004] Wed Nov 17 09:32:24 2010
procmail: Executing “/usr/bin/test,!=,”
procmail: Non-zero exitcode (1) from “/usr/bin/test”
procmail: No match on "/usr/bin/test != "
procmail: Assigning “DEFAULT=/home/myusername/Maildir/”
procmail: Assigning “ORGMAIL=/home/myusername/Maildir/”
procmail: Assigning “DROPPRIVS=yes”
procmail: Assuming identity of the recipient, VERBOSE=off
From useralias@domainname.com Wed Nov 17 09:32:19 2010
Subject: test 24
Folder: /home/myusername/Maildir/new/1289986344.12004_0.myservername 1271
Time:1289986344 From:useralias@domainname.com To:testingness@domainname.com User:myusername Size:1324 Dest:/home/myusername/Maildir/new/1289986344.12004_0.myservername Mode:None
Frustratingly, nothing gets added to ~/.procmail/log
How do I know procmail’s working at all? If I change the last line of /etc/procmailrc from $DEFAULT
as a destination to .Testingness/
then it does so.
