I’ve configured a few procmail filters and they don’t seem to work. I’ve made the rule that mail from a certain sender should be moved to a mailfolder, that didn’t work. Then I’ve tried to change the rule to throw away the mail when recieved, but that doesn’t work either.
I suspect not using the install.sh is the issue – something in the mix isn’t configured quite right. It’s hard to tell exactly what, there’s a lot of moving parts in this realm
Do you see any errors in the mail log? If something is awry with Postfix or procmail, it may show up in the mail log.
Fluor:/home/thies # tail -f /var/log/mail.err
May 19 11:37:07 Fluor local[429]: fatal: execvp /etc/webmin/virtual-server/autoreply.pl: No such file or directory
May 19 11:51:54 Fluor local[678]: fatal: execvp /etc/webmin/virtual-server/autoreply.pl: No such file or directory
May 19 11:51:57 Fluor local[682]: fatal: execvp /etc/webmin/virtual-server/autoreply.pl: No such file or directory
May 19 12:01:25 Fluor local[1139]: fatal: execvp /etc/webmin/virtual-server/autoreply.pl: No such file or directory
Errors, yes, but not related I think.
Fluor:/home/thies # tail -f /var/log/mail.warn
May 27 19:14:48 Fluor postfix/smtpd[30848]: warning: 190.188.106.5: address not listed for hostname 5-106-188-190.cab.prima.net.ar
May 27 19:17:10 Fluor postfix/smtpd[30848]: warning: 189.25.88.175: address not listed for hostname 18925088175.user.veloxzone.com.br
May 27 19:18:31 Fluor postfix/smtpd[30848]: warning: 88.146.158.226: address not listed for hostname cl226.zl1.tcservis.cz
May 27 19:18:33 Fluor postfix/smtpd[30848]: warning: 88.146.158.226: address not listed for hostname cl226.zl1.tcservis.cz
Also not related.
It almost looks like procmail doesn’t run… or is it only invoked? (I’m kinda a procmail noob).
Since you have “LOGFILE=/var/log/procmail.log” set in the procmailrc, that’s making me think procmail isn’t running.
What permissions do you have set on /usr/bin/procmail? My system has:
[code:1]
ls -l /usr/bin/procmail
-rwsr-sr-x 1 root mail 72316 2007-03-27 14:35 /usr/bin/procmail
[/code:1]
However, normally Virtualmin uses this as the mailbox_home:
[code:1]mailbox_command = /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME[/code:1]
But that requires the procmail-wrapper package from the Virtualmin repository. Normally, that’s setup by the installer – but you can manually add the repository to your system, or even manually download the package from:
It looks like you’re right, but I’ve tried several options in main.cf and they won’t load for some reason…
When I check the config in webmin:
main.cf
parameters defined as per defaults
command_directory /usr/sbin
config_directory /etc/postfix
debug_peer_level 2
defer_transports
disable_dns_lookups no
disable_mime_output_conversion no
inet_interfaces all
mail_owner postfix
mail_spool_directory /var/mail
mailbox_command
mailbox_transport
so no mailbox_command directive.
edit: my god, I’m stupid… it was put in the main.cf twice, and the last had precedence.
hi Joe, hi Eric,
I need some help concerning procmail too.
I used your install-script for setting up the system.
Following problem:
-If an e-mail user logs into his usermin account and sets a forwarding rule (forward to address xxx and deliver to mailbox), the forwarding doesn’t work. delivering to the mailbox works.
-If the server-owner creates the same rule for the e-mail user in his virtualmin account, forwarding works fine.
There seems to be a problem with procmail because the logfile /var/log/procmail.log is empty, the result from:
[code:1]Jun 6 01:36:40 v10 procmail[14579]: Error while writing to "/var/log/procmail.log"
Jun 6 09:52:25 v10 procmail[1561]: Error while writing to "/var/log/procmail.log"
Jun 6 10:05:18 v10 procmail[2315]: Error while writing to "/var/log/procmail.log"
Jun 6 10:26:46 v10 procmail[3971]: Error while writing to "/var/log/procmail.log"[/code:1]
hi Joe, hi Eric,
Following problem:
