Problems, virtualmin whit wordpress
Hi, i have run ubuntu server 12.04… webmin 1.160. and virtualmin the last version my system is SuperMicro X6DHR 8G2
When i create a new virtualserver in virtualmin exemple abc.xxx.com, its oke, the dbase will be create automatic to…
1… i upload wordpress to the virtualserver abc.xxx.com, and install, there begin the problem, there is no config.php, so i have to copy the sugest config and copy this to sample-config.php and rename it to wp-config.php.
wordpress works ?? but when im try to make a new post or page , im not see the WYSIWYG)… only the HTML … the map rules are 775
Who can help me to fix this,
Take a peek in $HOME/logs/error_log whenever you try to access your WordPress site. Do any errors show up in there?
Hi eric, i see no strange errors in $HOME/logs/error_log
the problem is not when im log in, but when i try to put a new message or make a new page
Perhaps a bug in the actual software? Have you talked to the Wordpress community?
Best Regards, Peter Knowles TPN Solutions
E: pknowles@tpnsolutions.com
P: 604-782-9342
W: http://www.tpnsolutions.com
