removing virtualmin using the install script with option --uninstall.
tried to install with install script (both GPL and Pro) but it failed to install packages (see error-log, script warns that installation will fail on systems not listed, which is the case)
then I followed the steps for manual installation: Downloaded "webmin_1.450_all.deb", "usermin_1.380_all.deb", "webmin-virtual-server_3.66.gpl_all.deb" and "webmin-virtual-server-theme_6.7_all.deb" and installed them using dpkg - went all well, system is now running as before.
checked again permissions of procmail -> 6755 (ok)
But I still get the error that setuid/setgid do not work. Do you know how I can test these functions e.g. with a small test script? If it works we can assume that the error is in the procmail-wrapper or the plugin-check…
One thing you should check is if Postfix is configured with the correct path to procmail. Try running the following command, and posting the output here :
I see the only way to resolve the problem by having a look at save_newfeature.cgi which performs the validation (feature_check?) of all features. But I’m too less experienced in pearl programming to reverse-ingeneer it on my own…
mailbox_command = /usr/bin/procmail -a “$EXTENSION”
I too were getting the
Failed to save enabled features : The procmail command procmail has 0 permissions, when it should be setuid and setgid to root. Email may not be properly delivered or checked for spam.
error.
To fix my version of this issue i did the following
Change procmail to root from mail group;
–Run from terminal–
note the inclusion of the S’s { -rwSr-sr-x }
Now re-run the re-check config and you should not get this error again.
Hope this helps someone and I thought I would share my experince on this issue so next time I go to re-install virtualmin and get this error again, I will know were to come and find the solution for it…
