My system is CentOS 6.5 i386, when I start Virtualmin GPL as the Guide: http://www.webmin.com/vinstall.html, I used three lines command:
wget http://software.virtualmin.com/gpl/scripts/install.sh
chmod +x install.sh
./install.sh
when Installing dependencies using some command, time is out… following is the code:
|http://software.virtualmin.com/gpl/rhel/6/i386/httpd-2.2.15-39.el6.vm.i686.rpm: [Errno 12] Timeout on http://software.virtualmin.com/gpl/rhel/6/i386/httpd-2.2.15-39.el6.vm.i686.rpm: (28, ‘Operation too slow. Less than 1 bytes/sec transfered the last 3 seconds’)
Trying other mirror. /http://software.virtualmin.com/gpl/rhel/6/i386/mod_ssl-2.2.15-39.el6.vm.i686.rpm: [Errno 12] Timeout on http://software.virtualmin.com/gpl/rhel/6/i386/mod_ssl-2.2.15-39.el6.vm.i686.rpm: (28, ‘Operation too slow. Less than 1 bytes/sec transfered the last 3 seconds’)
Trying other mirror. |
Error Downloading Packages:
1:httpd-2.2.15-39.el6.vm.i686: failure: httpd-2.2.15-39.el6.vm.i686.rpm from virtualmin: [Errno 256] No more mirrors to try.
2:mod_ssl-2.2.15-39.el6.vm.i686: failure: mod_ssl-2.2.15-39.el6.vm.i686.rpm from virtualmin: [Errno 256] No more mirrors to try.
How to solve this problem, please help!
