Hi guys!
I’m running Ubuntu 12.04 LTS on Linode. I have installed Webmin but am getting errors with Virtualmin.
Below is the output:
[code]Your system has 991.19 MB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the Postfix Mailserver module.
PHP execution via fcgid requires the Apache mod_fcgid module
… your system is not ready for use by Virtualmin.[/code]
What I attempted so far:
I attempted to enable fcgid in Webmin > Servers > Apache Webserver > Global configuration > Configure Apache Modules.
When I check the box for fcgid and click “Enable Selected Modules”, then click “Start Apache”, I get the following error:
[code]Failed to start apache :
- Starting web server apache2
- The apache2 instance did not start within 20 seconds. Please read the log files to discover problems[/code]
Any ideas what I should be doing to fix this?
- Dustin
