I was able to setup virtualmin, swap… so basicly the system is running fine, I have disabled mail and spam services so that I have enough memory on my 512MB VPS.
I was able to move Mysql db and files to my vps. Blog seems to work, With the help of this forum I was able to fix permissions after zip extraction.
I have only one problem now, pictures are not showing up. after googling the only thing that looks to be the problem is mod_rewrite not working.
I checked webmin - servers - apache webserver - global configuration - configure apache modules - rewrite is enabled.
I also found one post to enable mod_rewrite: edit /sites-enabled/000-default and set AllowOverride to All.
Problem is that site is still not showing pictures (i reenabled permalinks).
Are there any other settings for mod_rewrite?
Regarding site transfer, its very simple, domain is the same so it should not be a problem.
From cpanel to cpanel hosting transfer there was never a problem.
No, in logs there is nothing that could point to the problem.
There are some errors for 22th September, that files don’t exist, but, I think I fixed that as I don’t have any errors since then.
I checked accessed log and there are records for today.
