But, from the browser ‘project.user.site.com’ redirect to webroot father server ‘/home/user/public_html’, not to '/home/user/domains/project.user.site.com/public_html
The status of your system is being checked to ensure that all enabled features are available,
that the mail server is properly configured, and that quotas are active ..
Your system has 3.37 GB of memory, which is at or above the Virtualmin recommended
minimum of 256 MB.
However, the default master DNS server localhost is not a fully qualified domain name.
Apache is installed.
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and assumed to be running.
Plugin DAV Login is installed OK.
Plugin AWstats reporting is installed OK.
Plugin Mailman is installed OK.
Plugin Protected web directories is installed OK.
Using network interface eth0 for virtual IPs.
IPv6 addresses are available, using interface eth0.
Default IP address for virtual servers is 10.168.0.18.
Both user and group quotas are enabled for home and email directories.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
Your system is ready for use by Virtualmin.
I just see:
Where can I change the master DNS server? Is the master DNS server the same that the hosname from the computer? In my case ‘user’?
if you log into a shell and type: hostname
Does it say localhost? if yes then type: hostname host.domain.tld
that must be your FQDN like server01.domain.com and must be resolvable.
You can (read must) also set the hostname also via webmin - Networking - Network Configuration - Hostname and DNS Client
