I tried to update my virtualmin server by pressing the install all updates button and got the following errors
Now updating bind9 …
Installing package(s) with command apt-get -y --force-yes -f install bind9 ..
.. install failed!
Now updating libapache2-mod-fcgid …
Installing package(s) with command apt-get -y --force-yes -f install libapache2-mod-fcgid ..
.. install failed!
Now updating libpg-perl …
Installing package(s) with command apt-get -y --force-yes -f install libpg-perl ..
.. install failed!
Now updating mailman …
Installing package(s) with command apt-get -y --force-yes -f install mailman ..
.. install failed!
Now updating php4 …
Installing package(s) with command apt-get -y --force-yes -f install php4 ..
.. install failed!
Now updating php4-cgi …
Installing package(s) with command apt-get -y --force-yes -f install php4-cgi ..
.. install failed!
Now updating php5 …
Installing package(s) with command apt-get -y --force-yes -f install php5 ..
.. install failed!
Now updating php5-cgi …
Installing package(s) with command apt-get -y --force-yes -f install php5-cgi ..
.. install failed!
Now updating usermin-virtual-server-theme …
Installing package(s) with command apt-get -y --force-yes -f install usermin-virtual-server-theme ..
.. install failed!
Now updating webmin-security-updates …
Installing package(s) with command apt-get -y --force-yes -f install webmin-security-updates ..
.. install failed!
Now updating webmin-virtual-server …
Installing package(s) with command apt-get -y --force-yes -f install webmin-virtual-server ..
.. install failed!
Now updating webmin-virtual-server-theme …
Installing package(s) with command apt-get -y --force-yes -f install webmin-virtual-server-theme ..
.. install failed!
Now updating webmin-virtualmin-awstats …
Installing package(s) with command apt-get -y --force-yes -f install webmin-virtualmin-awstats ..
.. install failed!
Now updating webmin-virtualmin-dav …
Installing package(s) with command apt-get -y --force-yes -f install webmin-virtualmin-dav ..
.. install failed!
Now updating webmin-virtualmin-mailman …
Installing package(s) with command apt-get -y --force-yes -f install webmin-virtualmin-mailman ..
.. install failed!
No packages were installed. Check the messages above for the cause of the error.
<- Return to package list
