Problem with ssl and apache
Greetings,
we are trying to deploy some installations of virtualmin GPL on machines with apache and ssl up and running
But when try to "rechek" virtualmin configuration we get this log:
Failed to save enabled features : The Apache configuration on your system appears to be missing the module mod_ssl, which is needed to host SSL websites. If you do not plan to host SSL sites, this feature should be disabled in Virtualmin’s module configuration page.
If we make webmin “aware” that ssl is enabled in apache, by adding SSL in webmin’s apache module -> global configuration -> edit defined parameters, we get:
Failed to save enabled features : The Apache configuration on your system does not appear to be listening on port 443, which is needed to host SSL websites. If you do not plan to host SSL sites, this feature should be disabled in Virtualmin’s module configuration page.
BUT, this is’nt true, because apache is listening (and answering) correctly on port 443.
Any clue to solve the problem?
Specs of machine running virtualmin:
OS Gentoo
Virtualmin 3.49
Webmin 1.350
Webmin doesn’t know where to find all of the Apache configuration. You’ll need to figure out where include files are coming from, and make the Apache module aware of that location in the Module Config for that module. Gentoo is still pretty newly supported by Webmin and Virtualmin, and there are very few users using it. We’d love to get some bug reports with correct configuration file information for Gentoo, so once you get the locations figured out, let us know and future revisions of Webmin will be smarter about Gentoo.
Hi Joe,
I’ll be happy to give u all information needed to make gentoo fully supported (or at least working) by webmin/virtualmin.
Main configuration file is in /etc/apache2/httpd.conf and I think that virtualmin can read it.
The ssl directives come from /etc/apache2/modules.d/40_mod_ssl.conf
here is the contenent:
[code:1]<IfDefine SSL>
<IfModule !mod_ssl.c>
LoadModule ssl_module modules/mod_ssl.so
</IfModule>
</IfDefine>
<IfModule mod_ssl.c>
This is the Apache server configuration file providing SSL support.
It contains the configuration directives to instruct the server how to
serve pages over an https connection. For detailing information about these
directives see <URL:http://httpd.apache.org/docs-2.0/mod/mod_ssl.html>
Do NOT simply read the instructions in here without understanding
what they do. They’re here only as hints or reminders. If you are unsure
consult the online docs. You have been warned.
Pseudo Random Number Generator (PRNG):
Configure one or more sources to seed the PRNG of the SSL library.
The seed data should be of good random quality.
WARNING! On some platforms /dev/random blocks if not enough entropy
is available. This means you then cannot use the /dev/random device
because it would lead to very long connection times (as long as
it requires to make more entropy available). But usually those
platforms additionally provide a /dev/urandom device which doesn’t
block. So, if available, use this one instead. Read the mod_ssl User
Manual for more details.
Note: This must come before the <IfDefine SSL> container to support
starting without SSL on platforms with no /dev/random equivalent
but a statically compiled-in mod_ssl.
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
#SSLRandomSeed startup file:/dev/random 512
#SSLRandomSeed startup file:/dev/urandom 512
#SSLRandomSeed connect file:/dev/random 512
#SSLRandomSeed connect file:/dev/urandom 512
When we also provide SSL we have to listen to the
standard HTTP port (see above) and to the HTTPS port
Listen 443
SSL Global Context
All SSL configuration in this context applies both to
the main server and all SSL-enabled virtual hosts.
Some MIME-types for downloading Certificates and CRLs
<IfModule mod_mime.c>
AddType application/x-x509-ca-cert .crt
AddType application/x-pkcs7-crl .crl
</IfModule>
Pass Phrase Dialog:
Configure the pass phrase gathering process.
The filtering dialog program (`builtin’ is a internal
terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog builtin
Inter-Process Session Cache:
Configure the SSL Session Cache: First the mechanism
to use and second the expiring timeout (in seconds).
#SSLSessionCache none
#SSLSessionCache shmht:logs/ssl_scache(512000)
#SSLSessionCache shmcb:logs/ssl_scache(512000)
#SSLSessionCache dbm:/var/cache/apache2/ssl_scache
SSLSessionCache shm:/var/cache/apache2/ssl_scache(512000)
SSLSessionCacheTimeout 300
Semaphore:
Configure the path to the mutual exclusion semaphore the
SSL engine uses internally for inter-process synchronization.
SSLMutex file:/var/cache/apache2/ssl_mutex
</IfModule>[/code:1]
Apache webmin’s module is aware of this file (at least I think so).
PLease let me know if any other information is needed.
UP
Joe, pls consider that we can make available, test machines for u, to check what is wrong. Of course gentoo based :wink:
Thank u
