I just installed Virtualmin on a fresh Debian 10.
(I used to use Virtualmin but it is the first time on a Debian 10)
I have a shared IP address configured in it.
When i create a new virtual server, i select “Shared, on non-default IP” and keep “External IP address” on “Same as real address”.
But after that, the created DNS records are set on the internal server address !
When i check “Server Configuration” => “Change IP Address”, the “External IP address” is NOT set on “Same as real address”. I have to manually change it and then all is corrected.
So it seems the parameter “External IP address” => “Same as real address” is ignored at creation time.
