Virtualmin > Server Configuration > PHP Versions
On the right check the php version you want.
Be sure to recheck the configuration from System Settings - Re-Check Configuration first.
As far as I know the provision in Virtualmin to use multiple versions of PHP requires that the PHP alternate versions be built the same way that they are in the SCL or softwarecollections repositories - that is, they really need to be built specifically to be an ALTERNATE php version, and probably need to be rooted in /opt/rh/ to be recognized by Virtualmin.
i recheck the config and checked my php versions… it displays this message what i suppose to do now
“This virtual server is using the mod_php execution mode for PHP, such does not allow per-directory version selection.”
hi thank u for the help
i search for php5.2 in softwarecollections its not availble they have onlt latest repo … please i need to fix this
what i shud do now.
yes 5.2 is too old but i need to intall that for my project
