I have clean installation Debian 5.0 lenny and Virtualmin 3.76 GPL.
I created new virtual server and e-mail user.
I can send emails with TLS but I’ve got problem with receiving through POP3/SMTP (with SSL).
Log after connecting from MS Outlook 2007 in /var/log/mail.log:
Feb 23 09:32:03 hostname dovecot: pop3-login: Login: user=<user.domain>, method=PLAIN, rip=xxx.xxx.xxx.xxx, lip=xxx.xxx.xxx.xxx, TLS
Feb 23 09:32:03 hostname dovecot: POP3(user.domain): mkdir(/var/lib/dovecot/index/user.domain/.INBOX) failed: Permission denied
Feb 23 09:32:03 hostname dovecot: POP3(user.domain): mkdir(/var/lib/dovecot/control/user.domain/.INBOX) failed: Permission denied
Feb 23 09:32:03 hostname dovecot: POP3(user.domain): Couldn’t open INBOX: Internal error occurred. Refer to server log for more information. [2010-02-23 09:32:03]
Feb 23 09:32:03 hostname dovecot: POP3(user.domain): Couldn’t open INBOX top=0/0, retr=0/0, del=0/0, size=0
When I am logging to Usermin I can’t read e-mails too. there is red message:
An error occurred listing mail in this folder : Failed to login to POP3 server : Internal error occurred. Refer to server log for more information. [2010-02-23 09:31:38]
and logs after this IMAP connection:
Feb 23 09:31:38 hostname dovecot: imap-login: Login: user=<user.domain>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, secured
Feb 23 09:31:38 hostname dovecot: IMAP(user.domain): mkdir(/var/lib/dovecot/index/user.domain/.INBOX) failed: Permission denied
Feb 23 09:31:38 hostname dovecot: IMAP(user.domain): mkdir(/var/lib/dovecot/control/user.domain/.INBOX) failed: Permission denied
Feb 23 09:31:38 hostname dovecot: IMAP(user.domain): Connection closed
Permissions in /var/lib/dovecot:
hostname:/var/lib/dovecot# ls -l
total 12
drwxrwxrwx 2 root root 4096 Feb 23 08:28 control
drwxrwxrwx 2 root root 4096 Feb 23 08:28 index
-rw-r–r-- 2 root root 230 Feb 23 08:28 ssl-parameters.dat
I did’n modify any files after installation.
What can be wrong? This is a bug?
I read that changing in /etc/dovecot/dovecot.conf maildir from:
mail_location = maildir:~/Maildir:INDEX=/var/lib/dovecot/index/%u:CONTROL=/var/lib/dovecot/control/%u
to mail_location = maildir:~/Maildir
solve the problem, but I think that it isn’t the best way.
Have you got the same problem?
