Problem with install
Hello i have problem:
INFO - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
…in progress, please wait…
…E: Unable to locate package virtualmin-base
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
ruby is already the newest version.
unzip is already the newest version.
libapache2-mod-ruby is already the newest version.
libcrypt-ssleay-perl is already the newest version.
usermin is already the newest version.
webmin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 60 not upgraded.
INFO - 2011-02-09 16:48:18 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install postfix postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip quota: Succeeded.
INFO - 2011-02-09 16:48:18 - Succeeded.
INFO - 2011-02-09 16:48:18 - Installing Virtualmin and all related packages now using the command:
INFO - 2011-02-09 16:48:18 - /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install virtualmin-base
Reading package lists…
Building dependency tree…
Reading state information…
FATAL - Fatal Error Occurred: Installation failed: 0
where is the problem?
What distribution are you attempting to perform that installation on?
If you’re using the new Debian 6, or Squeeze, that’s not supported yet :slight_smile:
You can see a list of supported operating systems here:
http://www.virtualmin.com/os-support.html
Debian 6 should be supported within a few weeks.
Hello i’m using ubuntu server 10.10
Aha… okay, yeah, Ubuntu 10.10 isn’t supported either :slight_smile:
The only Ubuntu versions that are supported by the Virtualmin installer are the LTS releases… the most recent of which is 10.04.
You can get a list of what distributions and versions that are supported at this link here:
