We have just purchased and downloaded the unlimited version of virtualmin.
I am trying to install on a debian etch (kernel 2.6.24.4-grsec with grsecurity patch)
I get the following error:
#more virtualmin-install.log
INFO - 2008-04-07 11:07:36 - Started installation log in virtualmin-install.log
DEBUG - 2008-04-07 11:07:36 - Install mode: full
DEBUG - 2008-04-07 11:07:36 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2008-04-07 11:07:36 - install.sh version: EA4.3
INFO - 2008-04-07 11:07:36 - Checking for fully qualified hostname…
INFO - 2008-04-07 11:07:36 - Hostname OK: fully qualified as A094.server.lu
INFO - 2008-04-07 11:07:36 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2008-04-07 11:07:37 - Loading OS selection library…
INFO - 2008-04-07 11:07:37 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2008-04-07 11:07:37 - Loading OS list…
INFO - 2008-04-07 11:07:37 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2008-04-07 11:07:37 - Operating system name: Debian Linux
INFO - 2008-04-07 11:07:37 - Operating system version: 4.0
INFO - 2008-04-07 11:07:38 - Installing virtualmin-release package for Debian Linux 4.0…
INFO - 2008-04-07 11:07:38 - Enabling universe repositories, if not already available…
INFO - 2008-04-07 11:07:39 - Cleaning up apt headers and packages, so we can start fresh…
INFO - 2008-04-07 11:07:40 -
INFO - 2008-04-07 11:07:41 - Download of http://software.virtualmin.com/lib/apt.conf.noninteractive Succeeded.
INFO - 2008-04-07 11:07:41 - Disabling any CD-based apt repositories so the process can run without assistance
INFO - 2008-04-07 11:07:41 - Installing Webmin and Virtualmin package signing keys…
INFO - 2008-04-07 11:07:41 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin Succeeded.
INFO - 2008-04-07 11:07:41 - Download of http://software.virtualmin.com/lib/RPM-GPG-KEY-webmin Succeeded.
INFO - 2008-04-07 11:07:41 - OK
INFO - 2008-04-07 11:07:43 - Get:1
INFO - 2008-04-07 11:07:43 - Removing Debian standard Webmin package, if they exist (because they’re broken)…
INFO - 2008-04-07 11:07:43 - Removing Debian apache packages…
DEBUG - 2008-04-07 11:07:45 - Reading
INFO - 2008-04-07 11:07:45 - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes inst
all postfix postfix-tls postfix-pcre webmin usermin ruby libapache2-mod-ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip
INFO - 2008-04-07 11:07:45 - …in progress, please wait…
Reading package lists…
Building dependency tree…
postfix is already the newest version.
Note, selecting postfix instead of postfix-tls
webmin is already the newest version.
Setting up postgresql-7.4 (7.4.19-0etch1) …
Creating new cluster (configuration: /etc/postgresql/7.4/main, data: /var/lib/postgresql/7.4/main)…
Moving configuration file /var/lib/postgresql/7.4/main/postgresql.conf to /etc/postgresql/7.4/main…
Moving configuration file /var/lib/postgresql/7.4/main/pg_hba.conf to /etc/postgresql/7.4/main…
Moving configuration file /var/lib/postgresql/7.4/main/pg_ident.conf to /etc/postgresql/7.4/main…
Configuring postgresql.conf to use port 5432…
Starting PostgreSQL 7.4 database server: main.
Setting up postgresql-client (7.5.22) …
Setting up postgresql (7.5.22) …
Setting up procmail-wrapper (1.0-2) …
Setting up proftpd (1.3.0-19) …
Setting up proftpd-doc (1.3.0-19) …
Setting up rdoc1.8 (1.8.5-4etch1) …
Setting up rdoc (1.8.2-1) …
Setting up ri1.8 (1.8.5-4etch1) …
Setting up ri (1.8.2-1) …
Setting up scponly (4.6-1etch1) …
Setting up spamassassin (3.1.7-2) …
SpamAssassin Mail Filter Daemon: disabled, see /etc/default/spamassassin
Setting up spamc (3.1.7-2) …
Setting up subversion (1.4.2dfsg1-2) …
Setting up pflogsumm (1.1.0-3) …
FATAL - 2008-04-07 11:09:23 - Fatal Error Occurred: Installation failed: 1
FATAL - 2008-04-07 11:09:23 - Cannot continue installation.
FATAL - 2008-04-07 11:09:23 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2008-04-07 11:09:23 - re-attempted after any problems have been resolved.
FATAL - 2008-04-07 11:09:23 - Removing temporary directory and files.
FATAL - 2008-04-07 11:09:23 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2008-04-07 11:09:23 - in /root/virtualmin-install.log.
Maybe the following will help:
dpkg -C
The following packages have been unpacked but not yet configured.
They must be configured using dpkg --configure or the configure
menu option in dselect for them to work:
libapache-mod-php4 server-side, HTML-embedded scripting language (apache 1.3
virtualmin-base Meta-package that depends on all of the appropriate packa
The following packages are only half configured, probably due to problems
configuring them the first time. The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
apache-common support files for all Apache webservers
mailman Powerful, web-based mailing list manager
$ /usr/bin/apt-get -s install virtualmin-base
Reading package lists… Done
Building dependency tree… Done
virtualmin-base is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
4 not fully installed or removed.
Conf mailman (1:2.1.9-7 Debian:4.0r3/stable)
Conf apache-common (1.3.34-4.1+etch1 Debian:4.0r3/stable)
Conf libapache-mod-php4 (6:4.4.4-8+etch4 Debian:4.0r3/stable, Debian-Security:4.0/stable)
Conf virtualmin-base (1.0-17 )<br><br>Post edited by: angeloio, at: 2008/04/07 04:58
