Any clues in the error_log? This seems like there must be an error somewhere…either mod_perl2 isn’t working, or the code that inserts the tag is broken somehow.
I don’t think so. Now that I’m looking at this, we’ve seen this before in the issue tracker (also on a system with a from-source install of Apache). I’m pretty sure it was a problem with the mod_perl build. I’ll see if I can find that issue in the tracker.
So is this a problem with mod_perl2 or the Analytics module? I’m not a perl programmer but is their some direction you can point me in? I want to see if it’s possible to split the data the perl filter outputs so it doesn’t cut off.
This is the only mod_perl I use on the server. However, I was able to experiment with the perl module /usr/local/webmin-1.441/virtualmin-google-analytics/Virtualmin/GoogleAnalytics.pm
If I trim off the "$1" the google code and the rest of the document prints. However with the "$1" gone, if a add something like this: $f->print("HelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHelloHello");
right before $buffer = $addscript.$2.$3; the document cuts off again.
It’s almost as if it’s too much for mod_perl to print out.
