problem with enable ClamAV after fresh install
After a fresh install (SL 6.3) I walk through the post-installation wizard of Virtualmin Pro. A problem occured when I want to enable the Clam AV Virusscanner in the virus section:
A problem occurred testing the ClamAV server scanner :
ERROR: Can’t connect to clamd: No such file or directory
when I chose NO I can walk through, but, off course, I did not want that. I didn’t had that problem before with my other hosting servers
Can anyone help me out?
Yeah, that is an unusual issue… what happens if you manually restart ClamAV, does that resolve the issue?
You can do that by running this command as root on your server:
/etc/init.d/clamd restart
restart clamd gave:
Stopping Clam AntiVirus Daemon: [ OK ]
Starting Clam AntiVirus Daemon: [ OK ]
So it’s working fine. after setting it via webmin startup/shutdown. Maybe it’s a problem within the install.sh/installation of virtualmin?
Did try it also with Ubuntu 12.04.1 and the same problem appeared when trying enable clam av virusscanning at the post installation wizard.
Hmm, well, we haven’t run into that problem before, and the installer hasn’t changed recently.
Are you using a VPS, or a dedicated server?
If you’re using a VPS, is it by chance using OpenVZ? If so, can you paste in the contents of your /proc/user_beancounters file?
I am running several Hyper-V boxes with each 4 vps on it. I didn’t had that problem before until this week.
Strange…
I just encountered the same problem as pesja.
My system is an OpenVZ VPS running Debian 6.
running /etc/init.d/clamd restart as andreycheck suggested didn’t work. There is no clamd in /etc/init.d/
I instead ran /etc/init.d/clamav-daemon restart and the following was the output:
Stopping ClamAV daemon: clamd.
Clamav signatures not found in /var/lib/clamav … failed!
Please retrieve them using freshclam … failed!
Then run ‘/etc/init.d/clamav-daemon start’ … failed!
So as it says, I ran freshclam and the output was:
ClamAV update process started at Sat Nov 3 22:08:00 2012
Downloading main.cvd [100%]
main.cvd updated (version: 54, sigs: 1044387, f-level: 60, builder: sven)
Downloading daily.cvd [100%]
daily.cvd updated (version: 15535, sigs: 278578, f-level: 63, builder: guitar)
Downloading bytecode.cvd [100%]
bytecode.cvd updated (version: 191, sigs: 37, f-level: 63, builder: neo)
Database updated (1323002 signatures) from db.local.clamav.net (IP: 194.47.250.218)
After that, I ran /etc/init.d/clamav-daemon start
The daemon started, I went back to Virtualmin’s web interface, clicked “yes” for “Run ClamAV server scanner?”, I hit “Next”, and everything worked.
So in this case, the clamAV daemon wasn’t even running. Running freshclam and starting the daemon made the Virtualmin setup process for ClamAV run smoothly.
Didn’t work here either (Ubuntu 12.04LTS):
FYI: I just had to start the deamon.
Looks like Virtualmin can’t start it.
But this worked:
(here too, there is no /etc.init.d/clamd )
I then also had same issue with Spamassin not getting started properly by Virtualmin’s setup wizzard, but this fixed it:
/etc/init.d/spamassassin start
That worked for me also. When I run into de postinstalation, I also opened a terminal and started clamd (centos). Then I went to the step where I could select wether run clamav or not.
Because I started clamd the selection was already to Yes and I went with no futher problem to the next screen.
I am sure that something is changed after the end of september, because that was the date I installed 4 VirtualMachine’s with Centos and VM GPL. I didn’t experienced that problem then.
You might double-check if Webmin in general (recently) has a problem with starting/stopping services, by going to Webmin’s “System / Bootup and Shutdown” module, and see if you can start/stop ClamAV and Spamassassin there.
If that works, it might just be the Virtualmin installer / post-install wizard that has a problem.
Same here today with 2nd installation of Debian 7 on a dedicated server. The 1st installation went without issues.
This worked here too:
Again today with 3rd installation of Debian 7 on a virtual server.
That’s what I did:
[FAIL] Clamav signatures not found in /var/lib/clamav … failed!
[FAIL] Please retrieve them using freshclam … failed!
[FAIL] Then run ‘/etc/init.d/clamav-daemon start’ … failed!
freshclam
ERROR: /var/log/clamav/freshclam.log is locked by another process
ERROR: Problem with internal logger (UpdateLogFile = /var/log/clamav/freshclam.log).
reboot
[ ok ] Starting ClamAV daemon: clamd .
Hey all!
The problem still persists with a fresh Ubuntu 18.04 LTS installation with current Webmin/Virtualmin setup.
Thanks for sharing your experience!
I built Virtualmin on Ubuntu 18.04 at least 5 times in last 1 month with no issues whatsoever (as far as build/fresh installation of virtualmin is concerned). However, I just built a new server for Test purposes (before rolling out the new code changes on Prod Server) and I have seen this issue for the first time.
I have tried everything suggested in the forum but the service does not start at all and so the issue persists with both ClamAv as well as spamassassin and Webmin is not ready to be used and so I cannot oroiceed further,
However, the following 5 steps in exact same order did help me fix the issue:
  1. /etc/init.d/clamav-daemon start
  2. /etc/init.d/spamassassin start
  3. Restarted Webmin from within Webmin, waited for 2 mins
  4. Rebooted the Server
  5. Went back to Virtualmin -> System Settings -> Re-Check Configuration
Let the process run thru and it picked up everything needed and now the Webmin is ready to be used.
Hope this helps someone.
Thx: Rav
