Problem with dovecot after updating to Ubuntu 24
Ubuntu Linux 24.04.1
Virtualmin 7.20.2
Webmin 2.202
After migrating from Ubuntu Linux 22.04.5 users are unable to login
dovecot: imap-login: Fatal: Error reading configuration: read((fd)) disconnected before receiving end-of-settings line - Also failed to read config by executing doveconf: stat(/run/dovecot/config) failed: No such file or directory (path is from CONFIG_FILE environment)
dovecot: pop3-login: Fatal: Error reading configuration: read((fd)) disconnected before receiving end-of-settings line - Also failed to read config by executing doveconf: stat(/run/dovecot/config) failed: No such file or directory (path is from CONFIG_FILE environment)
solved
it was the dovecot.conf file witch have multiple entries for one domain…
@QPMReinhard can you hit that solved button :smile: and thanks for responding with the solution it will be helpful for others.
