OS: Debian 10 | Webmin: 1.984 | Virtualmin: 6.17-3 | node v16.14.2 | curl (7.64.0-4+deb10u2)
I’m not sure if this is the right forum. I apologize if it isn’t.
I use virtualmin and I have several virtualhosts with their respective domains. The server is in my house and has a private IP of 192.168.1.8, as a public IP I have a dynamic IP that I update when the electricity goes out (very rarely)
One of the domains, domain A, is the primary domain. This means that if from my local network I search for 192.168.1.8 domain A appears. This can be changed in Virtuamin → Server Configuration → Website Options → Default website for IP address
All domains are working properly and all websites hosted and managed by virtualmin are functional.
The problem came when I wanted to use puppeteer to take screenshots of some of my web pages. It always failed. It was able to capture the entire internet and my domain A, but it was unable to access domains B, C and D
I did tests to make sure. If from the terminal of my own server (debian) I try to curl domain A, I get the expected response, but if I try it with the other domains B, C and D, I get an error 7 for timeout after a good time waiting no results
If I try to ping domain A from my own server I get: 64 bytes from domainA.com (192.168.1.8): icmp_seq=1 ttl=64 time=0.132 ms
If I try to ping domains B, C and D from my own server, I get: 64 bytes from 175.red-79-148-220.dynamicip.rima-tde.net (79.148.220.175): icmp_seq=3 ttl =57 time=9.76 ms
NOTE: 79.148.220.175 is what it really returns, and I confirm that it is not my public IP
I would like to know why this happens and how I can solve it. I would like to be able to use curl and puppeteer on my own domains from the server itself. Some help?
UPDATE
Hi guys, it seems that I have already solved the problem.
We have to go to:
Networking → Networking configuration → Host Addresses
And add the domains in Hostnames
With that it is solved. Confirmed.
