Host operating system: Debian
Host OS version: 9
Webmin version 1.979
Virtualmin version 6.16 GPL / but just for testing for produktion it will be a pro version
Cloudmin version 9.5 Pro
I’ve questions/ problems with the Virtual Server Replication.
My plan:
- one system as master running cloudmin, virtuamin and other stuff.
- two systems to which the domins should be replicated to serve the content, get the mails and so on
I’ve: - mariadb cluster (maxscale and galera) for serving the DBs - works fine
- NFS cluster with drbd to hold the /home/cluster/* - works also
- LDAP cluster to store useres (connected to the three hosts and the NFS servers for the quota features - seems to work too (useres ar present and can be used/ quotas are shown)
- a load balencer infront of the hosts (ramdomly domains sould be use the LB or DNS-LB via cloudmin round-robin DNS records)
My questions / problems:
in the replicaqtion I select
- source to destination
- checked
All on source systemandDelete domains no longer on source
-All except selected features ..:Home directoryMariaDB database
- strage thing is when I set up cluster DNS to the two slaves and add
BIND DNS domaintoAll except selected features ..it say DNS domin already exist - if I change someting on the “master” i.e.
Mail for domain enabledis not replicated - if I delete the domian on the destination and replicate it is present
also if i disable a domain on the master it is not replicated
