I have opened a ticket about this 3 days ago but had
no response so I am trying here.
( I went to support tickets in my VirtualMin menu )
I opened an amazon account and have a working
"bucket". I have tested it by uploading a file using
Firefox S3 organizer plugin. So the bucket does work.
Here is what I did to try and do a backup:
And this is the error message I get.
Starting backup of 31 domains to Amazon S3 bucket heavyhoster ..
Failed to list S3 buckets : The difference between the request time and the current time is too large.
Backup failed! See the progress output above for the reason why.
Any ideas how to solve this ?
I want to offer hosting but part of that is having a very reliable backup and S3 seems the best way to go.
PS - I run VirtualMin Pro 3.67 on CentOS Linux 5<br><br>Post edited by: Davvit, at: 2009/04/13 03:36
I’m unfortunately not familiar with what would cause that (though I might verify your system time just in case).
However, this was a holiday weekend in the US, so those who may normally have responded to your Bug report may not have had as much time as usual to look at it.
I’d recommend posting a followup comment on your ticket, to remind folks to take a look at it
I don’!t think I can comment on my ticket because I marked it private
and I can not see it in the task list.
Anyway I would like to check and correct my server time.
I have never done that - where can I do that from ?
Is there a virtualmin module that allows me to do that ?
One other difficulty is that I am in Turkey - so I don’t know what the “correct” time should be!
My server is in USA leased from: Rackmounted.com
Datarealm Internet Services, Inc. Not sure which state they are in but Phone number code is 602. (Full number: 602-850-4044 )
Should I go by the times displayed on these posts ?
I don'!t think I can comment on my ticket because I marked it private
Private tickets should still be visible to the owner of the ticket. But, if it has been closed, it will no longer be visible in the default search. You can, of course, choose to look at closed tickets. Just open out the Advanced search (click it), and then choose "All Statuses" in the Status field, and enter your username in the Opened By field.
And yes, there is a module for time in Webmin. Webmin->Hardware->System Time.
It doesn’t matter what time zone you choose for your server, but the time needs to be accurate for that time zone. I happen to set our servers time zone to the one where the servers live (Dallas and Houston, in the Central time zone). An area code of 602 puts your server in Phoenix, Arizona (might be reseller of servers hosted by GoDaddy who are the largest host in that area), which is Mountain time zone (UTC-7), and the timezone selector in Webmin has a Phoenix, Arizona setting.
Once you’ve got the time set correctly, you’ll want to enable synching to a time server. Webmin can setup a cronjob for you, or you can just start the ntpd service (ntp is the network time protocol, which provides incredibly accurate time keeping). I usually use ntpd, but either is good enough for web service.
As I mentioned, there are two possibilities. The information you found is for ntpd. Webmin does not use ntpd…it merely does a sync periodically via a cronjob. The latter is lighter weight (no server running all the time) but less precise. You can use one or the other.
I guess that the Webmin module is updating this file for me
No. Webmin just sets up a cronjob that polls the server periodically. It does not setup ntpd. Which is why I said, "Webmin can setup a cronjob for you, or you can just start the ntpd service (ntp is the network time protocol, which provides incredibly accurate time keeping). I usually use ntpd, but either is good enough for web service."
ntpd is almost certainly already configured reasonably RHEL/CentOS packages are configured, by default, to sync to the Red Hat time server, I think. You just need to start it, if that’s how you want to sync time. Don’t bother messing with the configuration.
Lots of people are backing up to S3 (including us for some things). I think this error is legit. I’m guessing you still don’t have accurate time on your server. Check /var/log/messages for ntp related warnings…it will die if the time is too far off when it starts (changing time rapidly is dangerous because it can cause mail-related issues; Dovecot will shut down if you change time dramatically for example).
I just looked at my mail log and the last entries are:
Apr 20 05:09:33 heavyhoster postfix/qmgr[23170]: 03D567AE265: removed
Apr 20 05:12:40 heavyhoster postfix/anvil[32519]: statistics: max connection rate 1/60s for (smtp:88.226.251.95) at Apr 20 05:09:19
Apr 20 05:12:40 heavyhoster postfix/anvil[32519]: statistics: max connection count 1 for (smtp:88.226.251.95) at Apr 20 05:09:19
Apr 20 05:12:40 heavyhoster postfix/anvil[32519]: statistics: max cache size 1 at Apr 20 05:09:19
I also tried to access my email via Outlook Express and none of my accounts are respondeing - I get this error:
Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity. Account: ‘aa-ads.com’, Server: ‘mail.aa-ads.com’, Protocol: POP3, Port: 110, Secure(SSL): No, Error Number: 0x800CCC0F
and:
The host ‘mail.fethiye-guide.com’ could not be found. Please verify that you have entered the server name correctly. Account: ‘Fethiye-guide.com’, Server: ‘mail.fethiye-guide.com’, Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 11004, Error Number: 0x800CCC0D
I will try and close down and restart the Postfix server - may be that will help ?
When I went to re-start the mail server I noticed that Dovecot was down
so I re-started both postfix and Dovecot and now both my Outlook Express is accessing the server and the S3 backup worked !
I have changed my system time Phoenix Arizona time zone,
and I then set hardware time to this new system time.
Hopefully thats the right thing to do.
Finally on the "Time server sync" tab, I have set it to an hourly
sync but it looks like it wants a url in this box: Timeserver hostnames or addresses:
Is that where I put the "ntpd" that you mentioned ?
I googled and found the relevant website and it gives this info:
