I have problems with the server, install all the certificates and it works for an undetermined time not longer than 5 minutes, and it falls, it does not generate any error, it restarts apache, active ssl and nothing works, it can not be but it falls and it works when it is I want to attach images of the configuration and the tests made when it was working and suddenly I shut up, I’m desperate because I reinstalled the system 3 times thinking that errors are missing from the server but nothing works.
ssl installed correctly = https://i.stack.imgur.com/rV1L9.png
I verify that the ssl is working = https://i.stack.imgur.com/8p6eA.png
access_log = https://i.stack.imgur.com/yH5WW.png
error log = https://i.stack.imgur.com/FJ8Gu.png
what can I do that you recommend me thank you very much
