The new installation I only changed the system language: ZH_cn connect with the database. Click on the system configuration test after so
Operating environment:
LSB Version: :core-4.1-amd64:core-4.1-noarch
Distributor ID: CentOS
Description: CentOS Linux release 7.4.1708 (Core)
Release: 7.4.1708
Codename: Core
/bin/ls: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=3d705971a4c4544545cb78fd890d27bf792af6d4, stripped
http access shows
Error - Perl execution failed
Can’t locate /authentic-init.pm in @INC (@INC contains: /usr/libexec/webmin/authentic-theme/lib /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 . …) at /usr/libexec/webmin/authentic-theme/authentic-lib.pm line 18. Compilation failed in require at /usr/libexec/webmin/authentic-theme/index.cgi line 10.
Error log
Error
useradmin::list_users failed : Undefined subroutine &useradmin::passfiles_type called at /usr/libexec/webmin/useradmin/user-lib.pl line 114.
[04/Mar/2018:01:08:43 +0800] [140.205.205.25] /session_login.cgi : Perl execution failed : Can’t locate /authentic-init.pm in @INC (@INC contains: /usr/libexec/webmin/authentic-theme/lib /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 . …) at /usr/libexec/webmin/authentic-theme/authentic-lib.pm line 18.
Compilation failed in require at /usr/libexec/webmin/authentic-theme/session_login.cgi line 10.
server error log
[Sat Mar 03 23:42:27.253673 2018] [suexec:notice] [pid 18408] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sat Mar 03 23:42:27.275526 2018] [auth_digest:notice] [pid 18408] AH01757: generating secret for digest authentication …
[Sat Mar 03 23:42:27.276175 2018] [lbmethod_heartbeat:notice] [pid 18408] AH02282: No slotmem from mod_heartmonitor
[Sat Mar 03 23:42:27.335968 2018] [mpm_prefork:notice] [pid 18408] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 PHP/5.4.16 configured – resuming normal operations
[Sat Mar 03 23:42:27.335991 2018] [core:notice] [pid 18408] AH00094: Command line: ‘/usr/sbin/httpd -D FOREGROUND’
[Sun Mar 04 00:26:04.310277 2018] [mpm_prefork:notice] [pid 18408] AH00170: caught SIGWINCH, shutting down gracefully
[Sun Mar 04 00:27:21.083092 2018] [suexec:notice] [pid 1218] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Mar 04 00:27:21.121130 2018] [auth_digest:notice] [pid 1218] AH01757: generating secret for digest authentication …
[Sun Mar 04 00:27:21.122026 2018] [lbmethod_heartbeat:notice] [pid 1218] AH02282: No slotmem from mod_heartmonitor
[Sun Mar 04 00:27:21.806733 2018] [mpm_prefork:notice] [pid 1218] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 PHP/5.4.16 configured – resuming normal operations
[Sun Mar 04 00:27:21.806772 2018] [core:notice] [pid 1218] AH00094: Command line: ‘/usr/sbin/httpd -D FOREGROUND’
