Hello!
Because a problem restoring certain VS (existing mysql database and user) I deleted it from Virtualmin Panel and started a clean restore.
It seems like Awstats registry was not remove so I went to Webmin-Servers-Awstats and remove this VS
Started again and I get some copy errors I don’t understand how to solve them.
I am logged as root.
. configuration failed : Failed to copy /etc/php.ini to /home/blah/etc/php5/php.ini : cp: cannot create regular file `/home/blah/etc/php5/php.ini’: No such file or directory
… Webalizer reporting failed! : Failed to open /home/blah/public_html/stats/.htaccess.webmintmp.22753 : No such file or directory at …/web-lib-funcs.pl line 1331, line 1.
Adding DAV directives to website configuration …
… DAV Login failed! : virtualmin-dav::feature_setup failed : Failed to open /home/blah/etc/dav.digest.passwd : No such file or directory at …/web-lib-funcs.pl line 1331, line 1.
… AWstats reporting failed! : virtualmin-awstats::feature_setup failed : Failed to open /home/blah/cgi-bin/awstats.pl.webmintmp.22753 : No such file or directory at …/web-lib-funcs.pl line 1331, line 1.
Despite this errors it seems like the server is recreated but this stuff.
I am able to create new virtual servers but cannot restore because of this.
Thanks for any help
PS: I would like an option to continue restoring "mysql user exists … continue? "
PS2: I deleted this domain but not all features have been deleted: awstats.blah.conf has not
