i have try both freebsd 8.2 & 7.4 , both of them were show the same error message.
To run saslauthd from startup, add saslauthd_enable=“YES” in your
/etc/rc.conf.
===> Installing rc.d startup script(s)
===> Compressing manual pages for cyrus-sasl-saslauthd-2.1.23
===> Registering installation for cyrus-sasl-saslauthd-2.1.23
===> SECURITY REPORT:
This port has installed the following files which may act as network
servers and may therefore pose a remote security risk to the system.
/usr/local/sbin/saslauthd
This port has installed the following startup scripts which may cause
these network services to be started at boot time.
/usr/local/etc/rc.d/saslauthd
If there are vulnerabilities in these programs there may be a security
risk to the system. FreeBSD makes no guarantee about the security of
ports included in the Ports Collection. Please type 'make deinstall'
to deinstall the port if this is a concern.
For more information, and contact details about the security
status of this software, see the following webpage:
http://cyrusimap.web.cmu.edu/
INFO - Installing postfix from ports…
cd: can’t cd to /usr/ports/mail/postfix23
INFO - Installing dependencies using command:
INFO - for i in p5-Mail-SpamAssassin procmail p5-Class-DBI-Pg p5-Class-DBI-mysql openssl p5-Net-SSLeay python mailman ruby mysql50-server mysql50-client mysql50-scripts postgresql81-server postgresql81-client logrotate awstats webalizer php5 php5-mysql php5-mbstring php5-xmlrpc php5-mcrypt php5-gd php5-dom php5-pgsql php5-session clamav dovecot proftpd unzip p5-IO-Tty mod_perl2; do pkg_add -r $i; done
config: no rules were found! Do you need to run ‘sa-update’?
pkg_add: package ‘p5-Net-SSLeay-1.36’ or its older version already installed
pkg_add: package ‘mysql-client-5.0.92’ conflicts with mysql-client-5.1.55
pkg_add: please use pkg_delete first to remove conflicting package(s) or -f to force installation
pkg_add: pkg_add of dependency ‘mysql-client-5.0.92’ failed!
pkg_add: package ‘p5-DBD-mysql50-4.017’ conflicts with p5-DBD-mysql-4.017
pkg_add: pkg_add of dependency ‘p5-DBD-mysql50-4.017’ failed!
pkg_add: package ‘postgresql-server-8.1.23’ conflicts with postgresql-client-8.4.7
pkg_add: package ‘postgresql-client-8.1.23’ conflicts with postgresql-client-8.4.7
pkg_add: package ‘unzip-6.0’ or its older version already installed
pkg_add: unable to fetch ‘ftp://ftp.freebsd.org/pub/FreeBSD/ports/i386/packages-7.4-release/Latest/mod_perl2.tbz’ by URL
WARN - Something went wrong during installation: 0
WARN - FreeBSD pkd_add cannot reliably detect failures, or successes,
WARN - so we’re going to proceed as if nothing bad happened.
WARN - This may lead to problems later in the process, and
WARN - some packages may not have installed successfully.
WARN - You may wish to check /root/virtualmin-install.log for details.
INFO - Copying default my.cnf and initializing database…
cp: /usr/local/share/mysql/my-medium.cnf: No such file or directory
./install.sh: /usr/local/etc/rc.d/mysql-server: not found
INFO -
INFO - Initializing the clamav database. This may take a long time…
ClamAV update process started at Fri Mar 18 19:17:40 2011
Downloading main.cvd [100%]
main.cvd updated (version: 53, sigs: 846214, f-level: 53, builder: sven)
Downloading daily.cvd [100%]
daily.cvd updated (version: 12860, sigs: 74827, f-level: 60, builder: neo)
Downloading bytecode.cvd [100%]
bytecode.cvd updated (version: 142, sigs: 40, f-level: 60, builder: acab)
[LibClamAV] ******************************************************
[LibClamAV] *** Virus database timestamp in the future! ***
[LibClamAV] *** Please check the timezone and clock settings ***
Database updated (921081 signatures) from database.clamav.net (IP: 194.8.197.22)
WARNING: Clamd was NOT notified: Can’t connect to clamd through /var/run/clamav/clamd.sock
connect(): No such file or directory
chpass: user information updated
INFO - Installing procmail-wrapper.
fetch: http://software.virtualmin.com/gpl/freebsd/7.4/i386/procmail-wrapper: Not Found
FATAL - Fatal Error Occurred: Failed to download http://software.virtualmin.com/gpl/freebsd/7.4/i386/procmail-wrapper.
