Problem during installation (Segmentation fault tput rc)
Hello, I get a message during the installation Virtualmin. what does it mean? Does it important (any worry existed there)? or maybe any problem can be occurred after that? However it shows after that all of modules show installed but this makes my mind some curious about it. I also could not find resource for help about that. here is the line of fault during several Success lines in installation process. also the panel seems works well:
./slib.sh: line 206: 44425 Segmentation fault      tput rc
Thanks in advance.
I’ve seen that when memory got low during package installation. Was it around the point where yum or apt-get were running? (e.g. when the message was about installing something?)
It’s probably harmless. If phase 3 completed without error, it’s probably fine. You can run the configuration check once you’ve done the post-install wizard and it’ll catch most problems if there are any.
Dear @Joe, Thanks very much for the reply, And excuse me for answer. Actually it occured during the installation steps (like postfix, mariadb, dovecot and …).
I also installed it with in 1 GB RAM vm, I’m not sure that it cause problematic or each time I will get it even different . but actually all of other installation steps were finish successfully. I also haven’t seen any other related fault during installation step. Just one of service required to restart to work fine. I guess it was about memory read/write error. But seems good Idea, I will take a look for configuration check after post installation wizard completed and come back here if help needed. Thanks.
I ran into same problem during installation. I was trying to install on Centos7 minimum install. It was corrected by doing a standard install.
