I just installed virtualmin on a server that had previously been running Plesk. It seemed to be creating new virtual servers just fine until I realized it was putting all the accounts in /home/username
My server is partitioned with very little space in /home and LOTS of space in /var so I created /var/home and told virtualmin to use that for the homes.
Now I get this error when I do a recheck-config
Mail server Qmail is installed and configured.
The Suexec command on your system is configured to only run scripts under /home, but the Virtualmin base directory is /var/home. CGI and PHP scripts run as domain owners will not be executed.
I suppose I could remove /home and recreate a symbolic link to /var/home if that would work but I figured I better ask before trying it.
I think there is a trick I can do with mount to make it use that other file system with all the space…
Anybody got any ideas?
