Good afternoon, I am a new virtualmin user, I have a problem installing my scripts, I get a message that the virtual server does not meet the requirements, a mysql database is required, I do not have the option to edit databases as I have seen in the virtualmin panel, so I look for it in the search bar when I find the option and I want to create a database I receive the following error.
I just have made a clean install of Virtualmin 6.11 on CentOS 7 – it works flawlessly.
Looking at the Edit Databases page, makes me think that something is broken. Did you upgrade or patched Virtualmin files manually?
Try running:
yum reinstall wbm-virtual-server
Additionally, check /etc/webmin/virtual-server/domains find the record for domain you’re having an issue with and send it to me in a private message. Other than that, I could login and have a look. I don’t understand what’s happening off the cuff. I think you broke something unintentionally, as again, it works just fine for me out of the box.
