I am running Debian 7.4
I get the following:
The following packages were automatically installed and are no longer required:
procmail-wrapper usermin-virtual-server-theme webmin-security-updates
webmin-virtual-server-theme webmin-virtualmin-awstats webmin-virtualmin-dav
webmin-virtualmin-htpasswd webmin-virtualmin-mailman webmin-virtualmin-svn
Use ‘apt-get autoremove’ to remove them.
The following packages will be REMOVED:
postgresql* postgresql-9.1* postgresql-client* postgresql-client-9.1* postgresql-client-common*
postgresql-common* virtualmin-base*
0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
After this operation, 22.1 MB disk space will be freed.
Do you want to continue [Y/n]? n
(full log below)
root# apt-get remove --purge postgres*
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘postgresql-plperl-9.1’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pljava’ for regex ‘postgres*’
Note, selecting ‘postgresql-pltcl-9.1’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-ocaml’ for regex ‘postgres*’
Note, selecting ‘courier-authpostgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-server-dev-all’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres-copyd’ for regex ‘postgres*’
Note, selecting ‘postgresql-7.4’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-ocaml-vxgq8’ for regex ‘postgres*’
Note, selecting ‘postgresql-8.0’ for regex ‘postgres*’
Note, selecting ‘postgresql-8.1’ for regex ‘postgres*’
Note, selecting ‘postgresql-8.2’ for regex ‘postgres*’
Note, selecting ‘postgresql-8.3’ for regex ‘postgres*’
Note, selecting ‘postgresql-8.4’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-jdbc-java-doc’ for regex ‘postgres*’
Note, selecting ‘cl-sql-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-hdbc-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-hdbc-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘dpm-name-server-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql-filedump’ for regex ‘postgres*’
Note, selecting ‘sisu-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-simple-dev’ for regex ‘postgres*’
Note, selecting ‘python3-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-simple-doc’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-debversion’ for regex ‘postgres*’
Note, selecting ‘libghc-hdbc-postgresql-prof-2.3.2.1-b0d52’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-libpq-dev’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-ocaml-dev’ for regex ‘postgres*’
Note, selecting ‘libapq-postgresql3.2.0-dbg’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pgpool2’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-libpq-doc’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-ocaml-dev-vxgq8’ for regex ‘postgres*’
Note, selecting ‘libapq-postgresql3.2.0-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-hsql-postgresql-dev-1.8.1-2a1bd’ for regex ‘postgres*’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-prof-2.1.0-3f7e2’ for regex ‘postgres*’
Note, selecting ‘odbc-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-plperl’ for regex ‘postgres*’
Note, selecting ‘libwtdbopostgres-dev’ for regex ‘postgres*’
Note, selecting ‘postgresql-autodoc’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-libpq-prof’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-postgis’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-dbg’ for regex ‘postgres*’
Note, selecting ‘autopostgresqlbackup’ for regex ‘postgres*’
Note, selecting ‘gambas3-gb-db-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-preprepare’ for regex ‘postgres*’
Note, selecting ‘libghc-hsql-postgresql-prof-1.8.1-2a1bd’ for regex ‘postgres*’
Note, selecting ‘lua-sql-postgres’ for regex ‘postgres*’
Note, selecting ‘lua5.2-sql-postgres-dev’ for regex ‘postgres*’
Note, selecting ‘libghc6-hsql-postgresql-prof’ for regex ‘postgres*’
Note, selecting ‘perdition-postgresql’ for regex ‘postgres*’
Note, selecting ‘courier-authlib-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-hdbc-postgresql-prof’ for regex ‘postgres*’
Note, selecting ‘dpm-server-postgres’ for regex ‘postgres*’
Note, selecting ‘libghc-hdbc-postgresql-dev-2.3.2.1-b0d52’ for regex ‘postgres*’
Note, selecting ‘libgda-5.0-postgres’ for regex ‘postgres*’
Note, selecting ‘libapq-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘lua5.2-sql-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pgfincore’ for regex ‘postgres*’
Note, selecting ‘postgresql-server-dev-9.1’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-plr’ for regex ‘postgres*’
Note, selecting ‘ruby-dataobjects-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql-client’ for regex ‘postgres*’
Note, selecting ‘odbc-postgresql-dbg’ for regex ‘postgres*’
Note, selecting ‘pure-ftpd-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pljava-gcj’ for regex ‘postgres*’
Note, selecting ‘haskell-hsql-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘postgresql-contrib-9.1’ for regex ‘postgres*’
Note, selecting ‘lua-dbi-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-persistent-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-ip4r’ for regex ‘postgres*’
Note, selecting ‘akonadi-backend-postgresql’ for regex ‘postgres*’
Note, selecting ‘kexi-plugin-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-postgis-java’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-libpq-prof-0.8.2-39389’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pgmemcache’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-simple-prof’ for regex ‘postgres*’
Note, selecting ‘postgresql-plpython-9.1’ for regex ‘postgres*’
Note, selecting ‘eekboek-db-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-plpython3-9.1’ for regex ‘postgres*’
Note, selecting ‘liblua5.1-sql-postgres-dev’ for regex ‘postgres*’
Note, selecting ‘libghc6-hdbc-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-simple-prof-0.1.4.3-57f96’ for regex ‘postgres*’
Note, selecting ‘libghc6-hdbc-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘cl-sql-postgresql-socket’ for regex ‘postgres*’
Note, selecting ‘lua5.1-dbi-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-prefix’ for regex ‘postgres*’
Note, selecting ‘libapq-postgresql3.2.0’ for regex ‘postgres*’
Note, selecting ‘libghc-hsql-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘aolserver4-nspostgres’ for regex ‘postgres*’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-prof’ for regex ‘postgres*’
Note, selecting ‘libghc6-haskelldb-hdbc-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-hsql-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘webmin-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc6-haskelldb-hdbc-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘clisp-module-postgresql’ for regex ‘postgres*’
Note, selecting ‘lua5.1-sql-postgres-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-hsql-postgresql-prof’ for regex ‘postgres*’
Note, selecting ‘dpm-copy-server-postgres’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres-srmv22’ for regex ‘postgres*’
Note, selecting ‘postgresql-common’ for regex ‘postgres*’
Note, selecting ‘lfc-server-postgres’ for regex ‘postgres*’
Note, selecting ‘libreoffice-sdbc-postgresql’ for regex ‘postgres*’
Note, selecting ‘lfc-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-client-8.3’ for regex ‘postgres*’
Note, selecting ‘liblua5.1-sql-postgres-2’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pllua’ for regex ‘postgres*’
Note, selecting ‘freeradius-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-client-9.1’ for regex ‘postgres*’
Note, selecting ‘lua5.1-dbi-postgresql’ for regex ‘postgres*’
Note, selecting ‘gsql-postgresql-engine’ for regex ‘postgres*’
Note, selecting ‘postgresql-plpython3’ for regex ‘postgres*’
Note, selecting ‘librdf-storage-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-simple-dev-0.1.4.3-57f96’ for regex ‘postgres*’
Note, selecting ‘libdataobjects-postgres-ruby’ for regex ‘postgres*’
Note, selecting ‘lua-dbi-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘libghc-postgresql-libpq-dev-0.8.2-39389’ for regex ‘postgres*’
Note, selecting ‘postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘tntdb-postgresql3’ for regex ‘postgres*’
Note, selecting ‘postgresql-pl’ for regex ‘postgres*’
Note, selecting ‘openoffice.org-sdbc-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-orafce’ for regex ‘postgres*’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-dev-2.1.0-3f7e2’ for regex ‘postgres*’
Note, selecting ‘postgresql-client-common’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql-contrib’ for regex ‘postgres*’
Note, selecting ‘lua5.1-sql-postgres’ for regex ‘postgres*’
Note, selecting ‘falconpl-dbi-postgresql’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-plproxy’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pgq3’ for regex ‘postgres*’
Note, selecting ‘rt4-db-postgresql’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-gst’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-pgmp’ for regex ‘postgres*’
Note, selecting ‘postgresql-server’ for regex ‘postgres*’
Note, selecting ‘postgresql-pltcl’ for regex ‘postgres*’
Note, selecting ‘dpm-srm-server-postgres’ for regex ‘postgres*’
Note, selecting ‘spl-postgres’ for regex ‘postgres*’
Note, selecting ‘postgresql-plr’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.0-dbg’ for regex ‘postgres*’
Note, selecting ‘postgresql-doc-9.1’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres-srmv1’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres-srmv2’ for regex ‘postgres*’
Note, selecting ‘dsyslog-module-postgresql’ for regex ‘postgres*’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘postgresql-9.1-plsh’ for regex ‘postgres*’
Note, selecting ‘postgresql-plpython’ for regex ‘postgres*’
Note, selecting ‘lua-sql-postgres-dev’ for regex ‘postgres*’
Note, selecting ‘postgrey’ for regex ‘postgres*’
Note, selecting ‘haskell-hdbc-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘check-postgres’ for regex ‘postgres*’
Note, selecting ‘libghc6-hsql-postgresql-dev’ for regex ‘postgres*’
Note, selecting ‘libdataobjects-postgres-ruby1.9.1’ for regex ‘postgres*’
Note, selecting ‘libghc6-hsql-postgresql-doc’ for regex ‘postgres*’
Note, selecting ‘libpostgresql-jdbc-java’ for regex ‘postgres*’
Note, selecting ‘dpm-postgres-nameserver’ for regex ‘postgres*’
Note, selecting ‘libwtdbopostgres32’ for regex ‘postgres*’
Note, selecting ‘postgresql-plperl-8.4’ for regex ‘postgres*’
Note, selecting ‘gnustep-dl2-postgresql-adaptor’ for regex ‘postgres*’
Note, selecting ‘usermin-postgresql’ for regex ‘postgres*’
Note, selecting ‘kexi-postgresql-driver’ for regex ‘postgres*’
Note, selecting ‘libdataobjects-postgres-ruby1.8’ for regex ‘postgres*’
Package ‘libapq-postgresql-dev’ is not installed, so not removed
Package ‘courier-authpostgresql’ is not installed, so not removed
Package ‘postgresql-8.4’ is not installed, so not removed
Note, selecting ‘postgresql-9.1-plr’ instead of ‘postgresql-plr’
Note, selecting ‘libghc-hsql-postgresql-dev’ instead of ‘libghc-hsql-postgresql-dev-1.8.1-2a1bd’
Note, selecting ‘libghc-hsql-postgresql-prof’ instead of ‘libghc-hsql-postgresql-prof-1.8.1-2a1bd’
Note, selecting ‘libghc-postgresql-libpq-dev’ instead of ‘libghc-postgresql-libpq-dev-0.8.2-39389’
Note, selecting ‘libghc-postgresql-libpq-prof’ instead of ‘libghc-postgresql-libpq-prof-0.8.2-39389’
Note, selecting ‘libghc-postgresql-simple-dev’ instead of ‘libghc-postgresql-simple-dev-0.1.4.3-57f96’
Note, selecting ‘libghc-postgresql-simple-prof’ instead of ‘libghc-postgresql-simple-prof-0.1.4.3-57f96’
Package ‘libghc-persistent-postgresql-dev’ is not installed, so not removed
Note, selecting ‘libghc-hdbc-postgresql-dev’ instead of ‘libghc-hdbc-postgresql-dev-2.3.2.1-b0d52’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-dev’ instead of ‘libghc-haskelldb-hdbc-postgresql-dev-2.1.0-3f7e2’
Note, selecting ‘libghc-hdbc-postgresql-prof’ instead of ‘libghc-hdbc-postgresql-prof-2.3.2.1-b0d52’
Note, selecting ‘libghc-haskelldb-hdbc-postgresql-prof’ instead of ‘libghc-haskelldb-hdbc-postgresql-prof-2.1.0-3f7e2’
Package ‘postgresql-8.2’ is not installed, so not removed
Package ‘postgresql-8.1’ is not installed, so not removed
Note, selecting ‘dpm-copy-server-postgres’ instead of ‘dpm-postgres-copyd’
Note, selecting ‘dpm-name-server-postgres’ instead of ‘dpm-postgres-nameserver’
Note, selecting ‘dpm-server-postgres’ instead of ‘dpm-postgres’
Note, selecting ‘dpm-srm-server-postgres’ instead of ‘dpm-postgres-srmv1’
Note, selecting ‘dpm-srm-server-postgres’ instead of ‘dpm-postgres-srmv2’
Note, selecting ‘dpm-srm-server-postgres’ instead of ‘dpm-postgres-srmv22’
Note, selecting ‘lfc-server-postgres’ instead of ‘lfc-postgres’
Package ‘postgresql-pl’ is not installed, so not removed
Note, selecting ‘lua-dbi-postgresql’ instead of ‘lua5.1-dbi-postgresql’
Note, selecting ‘lua-dbi-postgresql-dev’ instead of ‘lua5.1-dbi-postgresql-dev’
Note, selecting ‘lua-sql-postgres’ instead of ‘lua5.1-sql-postgres’
Note, selecting ‘lua-sql-postgres’ instead of ‘lua5.2-sql-postgres’
Note, selecting ‘lua-sql-postgres-dev’ instead of ‘lua5.1-sql-postgres-dev’
Note, selecting ‘lua-sql-postgres-dev’ instead of ‘lua5.2-sql-postgres-dev’
Note, selecting ‘libpostgresql-ocaml’ instead of ‘libpostgresql-ocaml-vxgq8’
Package ‘postgresql-server’ is not installed, so not removed
Package ‘postgresql-postgis-java’ is not installed, so not removed
Package ‘postgresql-dev’ is not installed, so not removed
Package ‘postgresql-9.0-dbg’ is not installed, so not removed
Note, selecting ‘postgresql-plperl-9.1’ instead of ‘postgresql-plperl’
Note, selecting ‘postgresql-plpython-9.1’ instead of ‘postgresql-plpython’
Note, selecting ‘postgresql-plpython3-9.1’ instead of ‘postgresql-plpython3’
Note, selecting ‘postgresql-pltcl-9.1’ instead of ‘postgresql-pltcl’
Package ‘postgresql-7.4’ is not installed, so not removed
Package ‘postgresql-8.0’ is not installed, so not removed
Note, selecting ‘libpostgresql-ocaml-dev’ instead of ‘libpostgresql-ocaml-dev-vxgq8’
Note, selecting ‘postgresql-9.1-pljava-gcj’ instead of ‘postgresql-9.1-pljava’
Package ‘postgresql-client-8.3’ is not installed, so not removed
Package ‘postgresql-8.3’ is not installed, so not removed
Package ‘postgresql-9.1-pgq3’ is not installed, so not removed
Package ‘webmin-postgresql’ is not installed, so not removed
Package ‘usermin-postgresql’ is not installed, so not removed
Package ‘akonadi-backend-postgresql’ is not installed, so not removed
Package ‘aolserver4-nspostgres’ is not installed, so not removed
Package ‘libapq-postgresql3.2.0’ is not installed, so not removed
Package ‘libapq-postgresql3.2.0-dbg’ is not installed, so not removed
Package ‘libapq-postgresql3.2.0-dev’ is not installed, so not removed
Package ‘autopostgresqlbackup’ is not installed, so not removed
Package ‘kexi-postgresql-driver’ is not installed, so not removed
Package ‘kexi-plugin-postgresql’ is not installed, so not removed
Package ‘check-postgres’ is not installed, so not removed
Package ‘cl-sql-postgresql’ is not installed, so not removed
Package ‘cl-sql-postgresql-socket’ is not installed, so not removed
Package ‘clisp-module-postgresql’ is not installed, so not removed
Package ‘courier-authlib-postgresql’ is not installed, so not removed
Package ‘dsyslog-module-postgresql’ is not installed, so not removed
Package ‘eekboek-db-postgresql’ is not installed, so not removed
Package ‘falconpl-dbi-postgresql’ is not installed, so not removed
Package ‘freeradius-postgresql’ is not installed, so not removed
Package ‘gambas3-gb-db-postgresql’ is not installed, so not removed
Package ‘libpostgresql-gst’ is not installed, so not removed
Package ‘gnustep-dl2-postgresql-adaptor’ is not installed, so not removed
Package ‘gsql-postgresql-engine’ is not installed, so not removed
Package ‘haskell-hdbc-postgresql-doc’ is not installed, so not removed
Package ‘haskell-hsql-postgresql-doc’ is not installed, so not removed
Package ‘libghc6-haskelldb-hdbc-postgresql-dev’ is not installed, so not removed
Package ‘libghc6-haskelldb-hdbc-postgresql-doc’ is not installed, so not removed
Package ‘libghc6-hdbc-postgresql-dev’ is not installed, so not removed
Package ‘libghc6-hdbc-postgresql-doc’ is not installed, so not removed
Package ‘libghc6-hsql-postgresql-dev’ is not installed, so not removed
Package ‘libghc6-hsql-postgresql-doc’ is not installed, so not removed
Package ‘libghc6-hsql-postgresql-prof’ is not installed, so not removed
Package ‘libghc-hsql-postgresql-dev’ is not installed, so not removed
Package ‘libghc-hsql-postgresql-doc’ is not installed, so not removed
Package ‘libghc-hsql-postgresql-prof’ is not installed, so not removed
Package ‘libghc-postgresql-libpq-dev’ is not installed, so not removed
Package ‘libghc-postgresql-libpq-doc’ is not installed, so not removed
Package ‘libghc-postgresql-libpq-prof’ is not installed, so not removed
Package ‘libghc-postgresql-simple-dev’ is not installed, so not removed
Package ‘libghc-postgresql-simple-doc’ is not installed, so not removed
Package ‘libghc-postgresql-simple-prof’ is not installed, so not removed
Package ‘libghc-haskelldb-hdbc-postgresql-dev’ is not installed, so not removed
Package ‘libghc-haskelldb-hdbc-postgresql-doc’ is not installed, so not removed
Package ‘libghc-haskelldb-hdbc-postgresql-prof’ is not installed, so not removed
Package ‘libghc-hdbc-postgresql-dev’ is not installed, so not removed
Package ‘libghc-hdbc-postgresql-doc’ is not installed, so not removed
Package ‘libghc-hdbc-postgresql-prof’ is not installed, so not removed
Package ‘postgresql-9.1-ip4r’ is not installed, so not removed
Package ‘dpm-copy-server-postgres’ is not installed, so not removed
Package ‘dpm-name-server-postgres’ is not installed, so not removed
Package ‘dpm-server-postgres’ is not installed, so not removed
Package ‘dpm-srm-server-postgres’ is not installed, so not removed
Package ‘lfc-server-postgres’ is not installed, so not removed
Package ‘libgda-5.0-postgres’ is not installed, so not removed
Package ‘libpostgresql-jdbc-java’ is not installed, so not removed
Package ‘libpostgresql-jdbc-java-doc’ is not installed, so not removed
Package ‘libreoffice-sdbc-postgresql’ is not installed, so not removed
Package ‘lua-dbi-postgresql’ is not installed, so not removed
Package ‘lua-dbi-postgresql-dev’ is not installed, so not removed
Package ‘liblua5.1-sql-postgres-2’ is not installed, so not removed
Package ‘liblua5.1-sql-postgres-dev’ is not installed, so not removed
Package ‘lua-sql-postgres’ is not installed, so not removed
Package ‘lua-sql-postgres-dev’ is not installed, so not removed
Package ‘openoffice.org-sdbc-postgresql’ is not installed, so not removed
Package ‘postgresql-9.1-orafce’ is not installed, so not removed
Package ‘perdition-postgresql’ is not installed, so not removed
Package ‘postgresql-9.1-pgfincore’ is not installed, so not removed
Package ‘postgresql-9.1-pgmemcache’ is not installed, so not removed
Package ‘postgresql-9.1-pgpool2’ is not installed, so not removed
Package ‘postgresql-9.1-plr’ is not installed, so not removed
Package ‘postgresql-9.1-postgis’ is not installed, so not removed
Package ‘postgresql-plperl-8.4’ is not installed, so not removed
Package ‘postgresql-autodoc’ is not installed, so not removed
Package ‘postgresql-contrib’ is not installed, so not removed
Package ‘postgresql-doc’ is not installed, so not removed
Package ‘postgresql-server-dev-all’ is not installed, so not removed
Package ‘postgresql-9.1-debversion’ is not installed, so not removed
Package ‘postgresql-filedump’ is not installed, so not removed
Package ‘libpostgresql-ocaml’ is not installed, so not removed
Package ‘libpostgresql-ocaml-dev’ is not installed, so not removed
Package ‘postgresql-9.1-pgmp’ is not installed, so not removed
Package ‘postgresql-9.1-pljava-gcj’ is not installed, so not removed
Package ‘postgresql-9.1-pllua’ is not installed, so not removed
Package ‘postgresql-9.1-plproxy’ is not installed, so not removed
Package ‘postgresql-9.1-plsh’ is not installed, so not removed
Package ‘postgrey’ is not installed, so not removed
Package ‘postgresql-9.1-prefix’ is not installed, so not removed
Package ‘postgresql-9.1-preprepare’ is not installed, so not removed
Package ‘odbc-postgresql’ is not installed, so not removed
Package ‘odbc-postgresql-dbg’ is not installed, so not removed
Package ‘pure-ftpd-postgresql’ is not installed, so not removed
Package ‘python3-postgresql’ is not installed, so not removed
Package ‘librdf-storage-postgresql’ is not installed, so not removed
Package ‘rt4-db-postgresql’ is not installed, so not removed
Package ‘libdataobjects-postgres-ruby’ is not installed, so not removed
Package ‘libdataobjects-postgres-ruby1.8’ is not installed, so not removed
Package ‘libdataobjects-postgres-ruby1.9.1’ is not installed, so not removed
Package ‘ruby-dataobjects-postgres’ is not installed, so not removed
Package ‘sisu-postgresql’ is not installed, so not removed
Package ‘spl-postgres’ is not installed, so not removed
Package ‘tntdb-postgresql3’ is not installed, so not removed
Package ‘libwtdbopostgres-dev’ is not installed, so not removed
Package ‘libwtdbopostgres32’ is not installed, so not removed
Package ‘postgresql-9.1-dbg’ is not installed, so not removed
Package ‘postgresql-contrib-9.1’ is not installed, so not removed
Package ‘postgresql-doc-9.1’ is not installed, so not removed
Package ‘postgresql-plperl-9.1’ is not installed, so not removed
Package ‘postgresql-plpython-9.1’ is not installed, so not removed
Package ‘postgresql-plpython3-9.1’ is not installed, so not removed
Package ‘postgresql-pltcl-9.1’ is not installed, so not removed
Package ‘postgresql-server-dev-9.1’ is not installed, so not removed
